engine swap 2.4l 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by boyotamacoma, May 21, 2021.
  1. May 21, 2021 at 3:40 PM
    boyotamacoma
    boyotamacoma [OP] New Member
    longmont colorado
    1995 Taco 4x4
    4in lift, 18in wheels, cold air intake
    i have a 95 taco with the 2.4l engine, though this has been a reliable engine for me its just not cutting it anymore. Anyone know what can fit in there instead?
  2. May 21, 2021 at 4:01 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    4.8 LS swap for me after I retire.
    Key-Rei and boyotamacoma[OP] like this.
  3. May 23, 2021 at 7:00 PM
    moerose
    moerose Well-Known Member
    James
    98 sr5
    Lifted,33”2.7L turbo charged
    1uzfe out of a Lexus
    Key-Rei likes this.
  4. May 24, 2021 at 4:00 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Just bump up to 3rz if it's broken, but tbh if ur going to put the effort forth to make the 6 cyl work u could go v8 as mentioned. Mounts, crossmembers, ECU will all need to be changed.
    Have u even tried regearing yet? The 2rz is only a smaller bore/stroke than 3rz and is no pushover when it comes time for work
  5. May 24, 2021 at 4:10 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Pretty much anything can fit.
    Easiest swaps is the 3RZ 2.7 I4 and then the 5VZ 3.4l V6, after that it gets interesting as most everything will be stand alone custom one off fab work.
    There's probably some LS kits out there, maybe a 2UZ V8 kit to keep it in the family.
    The 1UZ V8 may be easier to find and get.
    But realistically the only option you should be considering is the flex fuel 5.7l 3UR-ZFE supercharged V8 from the tundra running e85 and shit ton of boost and timing.
    With this set up you won't have to worry about breaking axles as the tires will never stop spinning.
    :rofl:
    boyotamacoma[OP] and Wyoming09 like this.
  6. May 24, 2021 at 5:11 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It isonly limited by your skills or how big a budget you have.
    What is your end game full out race Truck Power can`t beat a small block chevy great parts and aftermarket support.
    Although unless you have Great self Control drive line parts will become second nature to change .
    Stay Toyota Go with the Proven 3.4 swap many on the road today lots of help
    Come Down to $$$$$$ or your Skill.
    It is not a good idea to have a shop never do a swap if it is never been done before.
    Best of Luck.
  7. May 24, 2021 at 5:15 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    If I was younger I would look real Hard at this 5.7l 3UR-ZFE swap to bad I don`t have a Trainee to watch over the shoulder.
    Key-Rei[QUOTED] likes this.
  8. May 30, 2021 at 3:16 PM
    boyotamacoma
    longmont colorado
    1995 Taco 4x4
    i am on a low budget with me being 16 but I'm trying to go for something like a baja truck style or the old tacoma race trucks
  9. May 30, 2021 at 4:00 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I would read and learn get as much hands on learning as I could .
    With little money this could be a very slow project .
    Then outside influences can also effect the outcome in both positive and negative directions .
  10. May 30, 2021 at 4:02 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    If you have a 4x4 you have the 2.7l engine not the 2.4l, the 2.4l was put in the 5lug 2wd Tacomas
  11. May 30, 2021 at 4:15 PM
    boyotamacoma
    longmont colorado
    1995 Taco 4x4
    i do in fact have a 2.4l in mine
  12. May 30, 2021 at 4:15 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  13. May 30, 2021 at 4:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
