Engine swap 2015 to 2005..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hrvrdh, Dec 24, 2018.
  1. Dec 24, 2018 at 7:09 PM
    hrvrdh
    hrvrdh [OP] Member
    2005 Tacoma TRD DCLB
    3" Procomp lift
    Hi fellas,
    Just wondering if it's possible to swap a 2015 4.0 automatic in to a 2005 4.0 automatic. Both are 4x4 and dclb. Same engines but what's it like under the hood? I'd take the trans tcase, ecu wiring harness from the 2015 as well. Anything else?
    Thanks for the advice in advance and happy holidays.
  2. Dec 24, 2018 at 7:10 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Youll have to swap your headers on the new motor or add the secondary air injection
    Kolter45 and hrvrdh[OP] like this.
  3. Dec 24, 2018 at 7:14 PM
    Muddinfun
    Muddinfun Well-Known Member
    From what @gearcruncher has said, the trans will be different internally.
  4. Dec 25, 2018 at 8:26 AM
    gearcruncher
    Canadain bumper technician
  5. Dec 25, 2018 at 8:29 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I would think you would definitely need the ECU from the '15. The '12+ has a different emissions control system with the air injection pump
    hrvrdh[OP] and gearcruncher like this.
  6. Dec 25, 2018 at 8:40 AM
    Plain Jane Taco
    USA
    I'll add.....the valves should already be in the right side exhaust manifold if it's a complete engine. However, you'll need to source the actual pump. Stay away from an ECU from a '12. It won't have the after shut down purge programming that the '13+ have
    hrvrdh[OP] likes this.
  7. Dec 25, 2018 at 8:48 AM
    Muddinfun
    It would be much easier to swap the exhaust header to the earlier one than to add the air pump, associated wiring, ECU, and then hope it's all happy with the existing wiring and electronics.
  8. Dec 25, 2018 at 9:18 AM
    hrvrdh
    hrvrdh [OP] Member
    3" Procomp lift
    Thanks for the info so far!
    I can take basically anything from the 2015 if needed. Would that make the swap more likely to work? Or would this project be a big pain in the ass?
  9. Dec 25, 2018 at 9:30 AM
    Plain Jane Taco
    USA
    That could probably work as well
  10. Dec 25, 2018 at 9:48 AM
    Muddinfun
    Adding a smog pump to a 2005 would be like adding catylitic converters to a '70 Chevelle, 454, 4 speed car. All you need to do is remove the air pump switching valves and right header off the '15 engine and install the '05 right header. You probably need to swap over the '05 engine wiring harness. If you're concerned about cosmetics, you can swap the right valve cover. Several people have done the swap, and I seriously doubt anyone has installed the air pump.
    Besides ALL that, if you install the '15 ECU, it's not going to play nice with the '05 transmission. And if you use the '15 trans and ECU, it's not going to be happy unless you install all the air pump stuff.
  11. Sep 7, 2019 at 9:39 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    What did you end up doing OP?
  12. Sep 7, 2019 at 2:48 PM
    hrvrdh
    hrvrdh [OP] Member
    3" Procomp lift
    Ditched the project entirely. Sounded like a pain in the balls. Haha
    henryp[QUOTED] likes this.
  13. Sep 8, 2019 at 1:10 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You thinking of a 2015 engine?
  14. Sep 8, 2019 at 7:11 AM
    henryp
    Henry
    Montana
    After reading all the transmission and SAI headaches probably not. Having a hard time finding a junkyard low mileage 2011 engine. Will probably go with rebuilt.
  15. Sep 8, 2019 at 8:04 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not sure how people are having transmission issues. That doesn't make sense.
    It is just swapping the components between the two engines. Then good to go.
    Pulled valve covers and swap on new engine. Pull headers and swap on new engine. Then new engine no longer has the '12+ SAIS stuff and plugs right up to the '09.
  16. Sep 8, 2019 at 8:07 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @mightytacoman just recently bought a used engine with great mileage. Maybe he can chime in where he got his?
    mightytacoman likes this.
  17. Sep 8, 2019 at 8:51 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Well I shopped around for a month or more using several different methods. Car-part being a major one and eBay actually. Searching on eBay requires several searches such as "1gr-fe" and "1grfe".. On car part, you need to change years your searching for by 2012+ or 05-11 and xrunner vs non xrunner.
    I eventually found this one on eBay. 2015 with 26000 miles on it for around $2500. Plus it comes with a bunch of extras such as the throttle body that I can turn around and sell to recoup some of the cost.
    Torspd likes this.
  18. Sep 8, 2019 at 9:12 AM
    henryp
    Henry
    Montana
    That makes way more sense. The internets wins again. The search continues. Thank you guys.
  19. Sep 8, 2019 at 2:31 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    you can't use the 2015 ECU as the body harness would not plug into the ECU. Best bet is use the 2005 harness, ecu, headers, and valve covers on the 2015 engine.
    Torspd likes this.
  20. Jun 8, 2020 at 11:02 AM
    henryp
    Henry
    Montana
    Which exhaust manifold gaskets did you go with? 2005-2011 or 2012+. Got a lightly used 2014 engine last week for the swap.
