engine swap? Drain auto?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Super Werty, Mar 5, 2012.
  1. Mar 5, 2012 at 9:42 AM
    Super Werty
    Super Werty [OP] Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    Does anyone know if I will need to drain the auto trans when I pull the motor?
    Thanks!
  2. Mar 5, 2012 at 9:47 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    It would be a good idea. The torque converter is bolted to the fly wheel. You'll still lose some fluid from the converter even with the tranny empty.
  3. Mar 5, 2012 at 9:48 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Or i suppose you could just unbolt the converter first and leave it attached to the tranny. Then you should be fine with the tranny full
  4. Mar 5, 2012 at 4:36 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
  5. Mar 5, 2012 at 5:50 PM
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    excuse my ignorance...but what is the converter?
  6. Mar 5, 2012 at 6:01 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    They are what automatic transmissions use instead of a clutch.
    http://auto.howstuffworks.com/auto-parts/towing/towing-capacity/information/torque-converter.htm
    it has a shitload of fluid in it, and no you don't need to drain the transmission, just unbolt the inspection plate, unbolt what bolts you can see, I would never recommend doing this by yourself because it will be a giant pain in the ass because you also need to rotate the motor by way of large breaker bar and socket on the pulley, this is to expose the rest of the bolts that connect the flywheel to the converter, that you have to unbolt one at a time. there should be six? and one will be colored differently.
  7. Mar 5, 2012 at 6:22 PM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    torque converter. kinda looks like a mini bundt pan lol.
  8. Mar 6, 2012 at 4:42 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Replace the seal on the torque converter when you swap the engine. 1:it is easy to get to with the engine out. 2:you disturbed the seal. Seals don't like to be disturbed and stressed, and usually start leaking shortly thereafter.
  9. Mar 6, 2012 at 7:39 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Good ideal^ Be sure when you put the convert back in it's ALL THE WAY BACK! if it's not and you bolt it all back together you'll break the pump gear. Another tip- when you pull it out to replace the seal do it quickly and put the converter front side down and you won't lose but a little bit of fluid.
  10. Mar 7, 2012 at 8:28 PM
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    ok so how do I do this when I can only turn the motor maybe 10%
    the rods are shattered and aren't allowing it to move
  11. Mar 7, 2012 at 8:48 PM
    Lucario Runner
    Lucario Runner Resident SUV racer
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Mostly the only thing here to be careful of is not damaging the fluid lines that go from the trans to the radiator.
  12. Mar 7, 2012 at 9:29 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    This is a large undertaking for someone who doesn't know what a catalytic converter is.
    Godspeed friend.
  13. Mar 8, 2012 at 1:17 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Take apart the motor til it can move.
  14. Mar 8, 2012 at 2:43 AM
    BRYLONATOR
    BRYLONATOR I now own a RAM....shoot me
    Denver, Colorado
    Chillin in a 120!
    This is so the right answer! But I also agree that knowing what a torque converter is should be a prerequisite for doing this type of work. Especially if you are going to replace the seal! It needs to be seated correctly when reinstalling it.
  15. Mar 8, 2012 at 4:16 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Hire a mechanic friend to help you. Disassembly is easy. Reassembling correctly, not so much.
  16. Mar 8, 2012 at 7:56 AM
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    I know what a cat is haha
    But my knowledge of trans and torque converter are limited. I had some knowledgable members on their way to help me but decided to let the dealer do it for me. I dont have time to let this drag out in case we didnt finish this weekend.
  17. Mar 8, 2012 at 11:35 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Good thinking that way any problems arise, they won't be on you to fix
