Engine swap from 3.4lt to 4.0 2001 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Odis, Aug 28, 2009.
  1. Aug 28, 2009 at 1:59 PM
    Odis
    Odis [OP] 01Taco
    Gurnee, Illinois
    4X4 TRD V6
    2 inch lift
    Can this be done easy. 2001 tacoma crewcab 4x4 3.4lt replace with a 4.0lt same trans?
  2. Aug 28, 2009 at 2:14 PM
    t33gee
    t33gee aka Tg
    Tyler
    Riverside, CA
    03 prerunner
    k and n CAI, magnaflow exhaust, NOS
    also interested in this question
  3. Aug 28, 2009 at 2:31 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Define easy?
  4. Aug 28, 2009 at 2:35 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
  5. Aug 28, 2009 at 2:49 PM
    Odis
    Odis [OP] 01Taco
    Gurnee, Illinois
    4X4 TRD V6
    2 inch lift
    Do you need to change motor mounts, Will the trans work correctly with it and any other modifications needed?
  6. Aug 28, 2009 at 2:56 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    The motor mounts will more than likely need changed as the frames are different between those generations. You would need the wiring harness and the ecu. The trans will more than likely not work since you would have to switch ecu's. If you wanted any working gauges, they would also need changed.
    So, I am going to say no on the easy part.
  7. Aug 28, 2009 at 3:09 PM
    Odis
    Odis [OP] 01Taco
    Gurnee, Illinois
    4X4 TRD V6
    2 inch lift
    Thanks appears to be too intense and to much work.
    Great Site here.
  8. Aug 28, 2009 at 3:12 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Welcome!
  9. Aug 28, 2009 at 5:15 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    Sacramento
    2008 TRD Off-Road
    Little this. Little that
    most times when you do a swap you'll need:
    new mounts
    new ECU
    new wiring harness
    new airbox/intake
    transmission adapter (sometimes)
    and more smaller stuff i can't list off the top of my head
    i looked into a simple 2.7L to 3.4L swap and it was going to be too much of a hassle.
    also, i see your an MP in the army, I'm currently in ROTC and am looking at either MP officer as well as some other MOS's. Care to share any info and helpful advise on your particular MOS?
  10. Aug 28, 2009 at 5:24 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    when my engine dies im swapping with a deisel
  11. Aug 28, 2009 at 8:21 PM
    pittim
    pittim mittip backwards
    Pink slider.
    I'd do a 1UZ or whatever the 4L V8 is over a 4L V6 considering the work involved.
    290hp/310 tq for the V8 about. I know someone with a 5lugger did the swap on here.
  12. Aug 29, 2009 at 10:03 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    4.7l and 270 hp
