Engine swap need advice
Discussion in '1st Gen. Tacomas (1995-2004)' started by Streettaco, Jul 12, 2016.
  1. Jul 12, 2016 at 6:41 AM
    Streettaco
    Streettaco [OP] Member
    Erik
    96 4 cyl
    N/A
    I want to swap my 4 cylinder 2.7 L in my 96 and put in a v6 3.4L any one know what needs to be replaced to make it compatible and possible costs
  2. Jul 14, 2016 at 6:27 PM
    TKGN1
    TKGN1 Well-Known Member
    Todd
    College Station, TX
    '01 DC TRD 4wd
    SAS on links, SC, flat bed
    Everything from a donor v6 truck.
    Entire wiring harness, from the front blinkers to the fuse block, everything.
    Tach is also different, swap the dash.
    Cut off 4 cyl motor mounts, weld in new v6 mounts (or cut off re-weld mounts from donor truck).
    Cost can be from 500 to 5000, dependent on how much said donor truck cost.
    Unless you get a screaming deal on a donor v6 truck, I'd stick with the 2.7.
    Been there.
  3. Jul 14, 2016 at 8:29 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    youre better off putting a 4cyl diesel in there. can someone chime in on a link about the benefits and or tutorial?
  4. Jul 15, 2016 at 1:03 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If your doing it for a project something to do go for it .
    Like any other engine swap if your on a tight budget you might want to rethink this .
    Buy a complete running donor vehicle and get it to where you are working
    Most often a bunch of little things we all forget if it is close at hand great other wise many trips going for forgotten parts
    I don`t know why you would want to swap the wiring harness .
    You just need to wire in the 4th ECM plug to the vehicle you have .
    EWD makes it easier.
    Really much easier to sell this one and buy the truck you want.
  5. Jul 15, 2016 at 4:53 PM
    markmb45
    markmb45 Well-Known Member
    Mark
    Utah
    99 4x4 Reg Cab 3.4, auto, e-locker
    V6,Auto, e-locker 4runner dash, seats
    I did the 3.4 swap in my 99 tacoma. Everyone is correct. A donor truck is the way to go. My donor was a 4runner. I replaced the complete wiring harness, and went with the auto tranny and interior, seats, dash etc. A lot of modifying motor mounts, shifter etc. Don't forget the instrument cluster needs replaced, the tach is specific to the number of cylinders. Well worth the extra work. But could nickel and dime you to death without a donor.
