engine swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Timicha, Aug 26, 2009.
  1. Aug 26, 2009 at 1:15 AM
    Timicha
    Timicha [OP] Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    I was wondering how hard it would be to swap out my 2.7 for a 3.4, has any one here done it, what all would i need, would my tranny bolt up to the 3.4 and are the mounts the same? if any one knows let me know cause its something i would really wanna do
  2. Aug 26, 2009 at 5:02 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    No - the mounts are not the same.
  3. Aug 26, 2009 at 8:45 PM
    Timicha
    TIM
    04 White Tacoma
    alright thanks for lettin me know
  4. Aug 26, 2009 at 9:01 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Time to get out your torch/plasma cutter, and welding machine. :D
  5. Aug 26, 2009 at 9:40 PM
    Turb0wned
    Turb0wned Well-Known Member
    Joel
    04 Tacoma Double Cab 4x4
    Im sure its not a hard swap, same chassis. I have swapped many motors in my life and if its a motor that was in a car with the same chassis it wont be bad.
    If you do the work you can get it done pretty cheap with some patience finding the parts... I've never done this swap but your probably looking at..
    -V6 Engine
    -Wiring harness
    -Tranny
    -ECU
    -Motor mounts and brackets
    -Tranny mount
  6. Aug 26, 2009 at 11:26 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    if i may, IMHO.. so about 3 weeks ago i blew my 3rd cylinder and burnt valves and a bunch of other stuff on my 2.7L. ive always wanted to do a swap for a 3.4. took my truck to an engine dude. it needed a whole new head job and new pistons etc. so i decided it would be more beneficial to just get a new rebuilt engine and drop it in. i looked into a 3.4 swap but the grand scheme of things it would cost almost 2.5 times the price. to fix the thing would be 3-4k. i found a guy who with install gave me a completely new rebuilt 2.7L with new pulleys, water pump, belts, steering belt, fan. the whole kittens mittens. for about 3k. i asked him if he could do a 3.4. with install and the new ECU, airbox, brackets, and everything else it was wayy more than i wanted, it came out to 7k+ in total. its deff not worth it. just sell the truck and get a 3.4.
    that is unless you have that much sitting around you could spend and not care...
    just my .02cents
  7. Aug 27, 2009 at 4:05 PM
    Timicha
    TIM
    04 White Tacoma
    ya but i bet half of that was labor haha. i would do all my own work along with rebuilding the engine my self
  8. Aug 27, 2009 at 4:06 PM
    Timicha
    TIM
    04 White Tacoma
    how hard is it to find all the wiring harnesses and ECU. and do you know if my 2.7 engine tranny would fit on a 3.4?
  9. Aug 27, 2009 at 4:16 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    you could check out your local auto junkyards and craigslist for totaled tacomas, look for people who are parting out. thats prolly your cheapest and most likely situation.
    from what ive read, i don't think the engine is a direct bolt on to the tranny. you need a bracket or something. idk. anyone care to chime in?!
  10. Aug 27, 2009 at 4:18 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    yea i bet some of it was labour, but then i looked at how cheap the 2.7L was with labor... kind of a big gap in price. he must really wanted extra to swap everything.
    he was a nice little vietnamese guy tho.
    funniest damn thing i heard in a while. he was looking at my 285s and commented "Your truck, too big tires, no go fast" i replied with, "it's not suppose to. its a pickup.."
  11. Aug 27, 2009 at 4:25 PM
    XBrown
    XBrown Spartacus!
    Xavier
    Phoenix, AZ
    04 Tacoma SR5
    If I remember right, all the Aisin W series transmission shared a bolt pattern. The W58, W59 trannys were for four cylinders, while the V6's got the stronger W150. I believe it's possible, but it may not last long.
  12. Aug 27, 2009 at 8:12 PM
    Turb0wned
    Joel
    The w58 tranny will have no problem holding up the power of the v6 motor as it came in N\A supras. I had an N/A MKIV supra with a 5spd w58 that i boosted and it held up just fine. Good for around 450-550 if you dont launch constantly. Now does it fit the tacoma v6 i dont know as agaim ive never done or even looked into that swap.
  13. Aug 27, 2009 at 8:56 PM
    XBrown
    XBrown Spartacus!
    Xavier
    Phoenix, AZ
    04 Tacoma SR5
  14. Aug 28, 2009 at 2:56 PM
    Timicha
    TIM
    04 White Tacoma
    haha thats pretty funny. mine still gets up and goes pretty good. just not a very high top speed
