Engine Swap?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SubFrozen, Oct 22, 2009.
  1. Oct 22, 2009 at 10:49 PM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    3" OME Heavy Duty Lift, 18" Chrome Rimes, ARB Front Bumper, K&N Cold Air Intake
    I have a V6 taco that ate it's innards. I'm looking at replacing the engine. What's a good swap? I'd like to keep it a 6 for economy.
    I was going to rebuild the current, but you have to toss the block and get a new one - can't bore it out. Phooey. So might as well look at options.
    Toss some ideas. Also, I may turn this into a very detailed DIY swap.
  2. Oct 22, 2009 at 10:54 PM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    Ive heard the viper v10 engine has been swapped by someone... idk, but if i ever get the chance, and find out its possible, im gonna do it
  3. Oct 22, 2009 at 10:55 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    find a wrecked 4runner with the v8 and swap that into it.
  4. Oct 22, 2009 at 10:56 PM
    j1999t
    Justin
    Northern Colorado
    traded it in
    and then supercharge it
  5. Oct 23, 2009 at 12:23 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    What do you mean by ate its innards?
  6. Oct 23, 2009 at 1:44 AM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    it was hungry and ate itself from the inside then blew up
  7. Oct 23, 2009 at 1:59 AM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
  8. Oct 23, 2009 at 7:09 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Find a wrecked 2010 Fj or 4Runner and get the Dual VVT-i 4.0 V6.
    eljedi68 likes this.
  9. Oct 23, 2009 at 7:10 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    He ran it out of coolant. Blew it up!
  10. Oct 23, 2009 at 7:10 AM
    NraFan
    JT
    SoCal
    Put a factory replacement v6. Keep it stock, keep the radiator full, and try not to kill this one!
  11. Oct 23, 2009 at 7:16 AM
    thedude5108
    thedude5108 Well-Known Member
    Jamie
    Los Olivos, CA
    07 Tacoma TRD 4x4 Dub cab
    16x8 Series 185 Eagle Alloys, Billy 5100's at 1.75, and a bitchin Mag Lite mount :)
    x2
  12. Oct 23, 2009 at 7:38 AM
    Joelito2983
    Joelito2983 Well-Known Member
  13. Oct 23, 2009 at 7:48 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  14. Oct 23, 2009 at 8:21 AM
    navysob
    navysob Carolina Alliance: Virginia Beach and Greenville
    Sean
    Virginia Beach, VA
    09 4x4 SR5
    28/20 Tint, Hood Protector, Vent Visors, 3" AAL's, Front Level Kit, Gas Shocks in the Rear, Tow Hitch, Black Step-Bars, Bull Bar, Off Road Lights
    Keep It Stock!!
  15. Oct 23, 2009 at 8:21 AM
    brandob9
    brandob9 Well-Known Member
    Brandon
    Portland, OR
    09 DC Long Bed
    Soundproofed cab, beeps purged, bed lights, extra bed tie-downs and TSB springs.
    For ~$2.5k, just get that FJ engine and call it a day. It'll be an easy swap. I'm guessing about 10-15 bolts, 10-15 hoses and about 10-15 electrical connectors.
    I've swapped in engines not originally destined for the recipient car before, and trust me, there will be eighteen small things waiting to be a real pain. If you want to get the truck going again, use a stock engine. You'll really appreciate having all the connectors line up.
  16. Oct 23, 2009 at 9:39 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    You'd be surprise of the amount of FJ, 4Runners, and Tacoma's out there that are wrecked due to roll overs. Your best bet is just to swap out the 4.0 for a 4.0. Although it would be cool to see the 4.7 V8 in another tacoma other than the SEMA truck. I'd say skip the lawyer and fighting with the dealer and toyota, the swap is your cheapest option. Good Luck.
  17. Oct 23, 2009 at 1:11 PM
    gcwaterski
    gcwaterski Well-Known Member
    If you can confirm for sure that the FJ engine is plug and play with our tacoma's- I would do that, hands down no questions asked! Otherwise I would just throw another 4.0L in there. I would only fool with a more complicated swap if you have another vehicle to be your daily driver, and some extra money laying around for some of those unforseen issues you will run into. Some mechanical aptitude helps too!
    Any time I have ever wanted to do a swap, the mechanics I dealt with really did not seem enthusiastic about attempting such a feat. (V8 in a 1995 wrangler)
    BUT if you have all of the above criteria, go big.
    Ha ha I know there is no way- and it would not be worth it if there was a way- but damn its just so pretty.
  18. Oct 23, 2009 at 2:32 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Can you not sleeve the block and build it? I'd do that before buying a totally new engine.
  19. Jun 16, 2010 at 5:03 PM
    75thrangertaco
    75thrangertaco Sua Sponte! RLTW
    charles
    casper wyoming
    procomp 6 inch co lift ,305/55/20 xtreme a/t tires,4.88 gears ,,grill shell painted white billet inserts.Trd cat back ,
    hmmm, you guys have the wheels turnin.a friend of mine and i, put a 5.9 cummins in a ranger. it took alot of chopping but it looked stock from the outside. i wonder if we can fit an iforce 5.7 in a taco.
  20. Jun 16, 2010 at 5:10 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    I wonder how hard that would be... I would guess the exhaust and everything would be the same, you would just need the 'puter out of the donor vehicle... hmm
    BUT, for the OP, I would say just get a junkyard 4.0 with the fewest miles on it you can find and go from there.
