Engine Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DCOGAR, May 28, 2019.
  1. May 28, 2019 at 10:14 AM
    DCOGAR
    DCOGAR [OP] Well-Known Member
    Daniel
    WV
    I am replacing the engine in my 05 with an engine from a 15. It looks like I am going to be getting the full wiring harness. I was told that I would have to swap out the oil pans and use my original manifolds. I know that it can't be that easy what am I missing? It is the 4.0.
  2. May 28, 2019 at 10:18 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I am curious what the answer is. I'm sure there must be some considerations related to the emissions nonsense on a 2015 engine vs 2005 engine.
  3. May 28, 2019 at 10:34 AM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    With apologies not sure who to tag in here @Torspd maybe? Anyway I was recently reading a similar thread and iirc the newer ecu would be needed also. Op, I’d google “05-15 Tacoma engine swap Tacomaworld” and start reading.
    Torspd likes this.
  4. May 28, 2019 at 10:53 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    As long as the 15 is from a Tacoma, then you don't need the full harness. Unless you just want a newer one. The '05 ecu won't run the SAIS system of the 2015 Tacoma.
    Basically this is what you need to do. Take your engine out. Look at what differences there are, and swap those parts onto the 2015 engine. There aren't many. Then install the 2015 engine into your truck. Drive and enjoy.
    Toy4me and Athlaos like this.
  5. May 28, 2019 at 2:39 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    We have a saying in the performance and tuning section. "Always trust in @Torspd" - since he has the most modified 1grfe in the entire world.
    Actually I don't think that's a saying, I just made that up on the spot. But the sentiment stands.
    Torspd[QUOTED] and DCOGAR[OP] like this.
  6. May 28, 2019 at 2:58 PM
    DCOGAR
    Daniel
    WV
    Torspd I sent you a message. I was thinking that I would be taking parts off the 05 and putting on the 15s engine block.
  7. May 28, 2019 at 5:02 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That's correct
