Engine swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomaguy06, Apr 5, 2020.
  1. Apr 5, 2020 at 5:37 AM
    Tacomaguy06
    Tacomaguy06 [OP] New Member
    Brad
    2006 blue Tacoma
    Hey guys, I have an 06 TRD sport with the 4.0L engine. I was able to get a engine and transmission out of a 2014 Tacoma also a 4.0L engine. Will the 2014 4.0L engine work in my 06 Tacoma??
  2. Apr 5, 2020 at 5:48 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    Yes, but emmisions are a bit different. Also probably needs a different ECU. Those are the basic things I know you'll need, I know more about the 2.7 that's that's all I know for sure.
  3. Apr 5, 2020 at 5:50 AM
    Tacomaguy06
    Brad
    2006 blue Tacoma
    I should be able to leave my wiring harness in the truck or does that need changed also? What is ECU?
  4. Apr 5, 2020 at 7:16 AM
    rdiddy_25
    rdiddy_25 Well-Known Member
    Rafael
    New Braunfels, TX
    2010 Tacoma DCLB 4x4
    Icon Stage 4 Suspension, Safari Snorkel
    Engine Control Unit. Essentially it’s the brain for your engine
  5. Apr 5, 2020 at 8:44 AM
    Muddinfun
    Muddinfun Well-Known Member
    You can not use the ‘14 transmission or ECU in your ‘06.
    You can use the ‘14 engine in your ‘06, but you must transfer the right exhaust manifold and a few things from your ‘06.
    TnShooter likes this.
