Engine Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jackson Fries, Apr 12, 2021.
  1. Apr 12, 2021 at 9:41 PM
    Jackson Fries
    Jackson Fries [OP] Active Member
    Hey guys doing an engine swap on my 07 Taco. The "new" engine is in and connected to the tranny and all. Anything I should do before starting it up? I'm double-checking all wires and hoses. 5.5 quarts of oil is what I hear it takes, the "new" engine is 2011. I'm doing a write-up on my experience after its running!
    tcjacado likes this.
  2. Apr 12, 2021 at 9:44 PM
    tcjacado
    tcjacado Well-Known Member
    Radiatior and all other fluid full, and hoses connected to the correct ports?
    Junkhead likes this.
  3. Apr 12, 2021 at 9:46 PM
    Bishop84
    Bishop84 Well-Known Member
    Not much to worry about, fluids, grounds, hoses, mounts tight.
    Make sure the coolant burps out the air while it idles and double check everything after a test drive.
  4. Apr 12, 2021 at 9:55 PM
    Waasheem
    Waasheem
    2007 xrunner
    I’d suggest to roll it to a clean dry spot. Then once you start it, it’s easy to see a leak. Clear any error codes, then recheck after the test drive.
  5. Apr 13, 2021 at 10:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  6. Apr 13, 2021 at 10:50 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Was the engine a rebuild (dry), or a runner (wet)? If it was dry, then I would roll it over a bunch before starting just to make sure you have oil at the top end.
    Yukon DoIt likes this.
  7. Apr 13, 2021 at 11:15 AM
    Inbred
    Inbred Well-Known Member
    Phinnius
    2nd generation euphoria
    Have fire extinguisher nearby
  8. Apr 13, 2021 at 4:37 PM
    Jackson Fries
    All great ideas haha especially the fire extinguisher lmao. Engine was sitting dry for a while in a doner truck ill be sure to turn it over with oil. Drivers cats are toast.
