Engine Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jroq43, Feb 15, 2022.
  1. Feb 15, 2022 at 11:06 AM
    jroq43
    jroq43 [OP] New Member
    joseph
    2005 Tacoma Prerunner SR5
    MaxTrac lift kit Method wheels
    I’m looking to swap my stock motor for a reliable engine for a full long travel rig that I’m trying to start building.
    what is the best motor I should look for?
  2. Feb 15, 2022 at 11:07 AM
    LiquidArrogance
    LiquidArrogance Well-Known Member
    Streets of Bakersfield
    2021 SSM Sport 4x4
  3. Feb 15, 2022 at 11:08 AM
    my2coma
    my2coma Active Member
    Jim
    Republic of Texas
    97 Tacoma 4x4 ext cab
    ARB front bumper, custom rear bumper, sliders, 4" lift, OME shocks, TRD e-locker rear axle, K&N cold air intake, Cobra CB, PIAA lights up front, Budbuilt skid plate, and several other goodies.....
  4. Feb 15, 2022 at 11:09 AM
    jroq43
    joseph
    I’m personally open to options. I don’t like to buy cheap stuff that’s not going to last. I’m looking for longevity. If I had to give a specific price I’d probably say 4k.
  5. Feb 15, 2022 at 11:13 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    4k would be a very cheap engine swap
  6. Feb 15, 2022 at 11:15 AM
    jroq43
    joseph
    I cool with buying something used with low miles on it, but im not exactly educated on any type of brand new engines.
  7. Feb 15, 2022 at 11:18 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Lexus IS 350 3.5L motor. Steering might be tricky though. 306HP. These engines pull pretty hard.
    LS 5.3L, but even if you purchased a low mileage engine and trans, gauges and fab work will be costly unless you do it yourself.
  8. Feb 15, 2022 at 11:33 AM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    the 4.0 is already a very reliable engine... anything else is going to be grief because of the custom work involved.
    you speak of long travel, whats your budget? Real life doesn't take Forza bucks
    vtown, tacoman45, Oreo Cat and 2 others like this.
  9. Feb 15, 2022 at 11:42 AM
    10YSON
    10YSON Well-Known Member
    GREG
    TACOMA & 4RUNNER
    TOTAL CHAOS / KING / DEAVER / PRP / DIRTKING
    The expensive stuff that comes with engine swapping a vehicle isn't even the engine itself. The transmission, transfer case, custom driveshafts and the electronics to support it will cost more than the engine. Add to it all the little stuff like an exhaust and all the mounts/cross members and the cost climbs even more.
    If it were me -- I'd get a gutted truck from a salvage yard and just start from scratch. All you need is a frame and cab.
  10. Feb 15, 2022 at 11:48 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    $4k all said and done? (Meaning buying the parts and covering all labor to have a reliable runner.) Then you're buying a used engine and most likely doing the great majority of work yourself.
    Key-Rei likes this.
  11. Feb 15, 2022 at 11:50 AM
    10YSON
    GREG
    TACOMA & 4RUNNER
    He makes a good point. I have total chaos LT on my truck I think my final invoice from TC was around $11,000 and install was $3700. Doing LT isn't cheap and FWIW I've never once wished my truck had more power. The stock 4.0 is plenty fast with a good suspension.
  12. Feb 15, 2022 at 12:22 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Mazda rotory
    6 gearT444E, wi_taco and 10YSON like this.
  13. Feb 15, 2022 at 1:21 PM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    This is just another thread about a motor swap that will never happen.
    vtown, b_r_o, 6 gearT444E and 5 others like this.
  14. Feb 15, 2022 at 1:24 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    3.5 ecoboost out of a Raptor.
  15. Feb 15, 2022 at 1:34 PM
    Boco10
    Boco10 Well-Known Member
    ADK
  16. Feb 15, 2022 at 1:38 PM
    LiquidArrogance
    2021 SSM Sport 4x4
    It's definitely on my "If When I When the Lottery" bucket list.
  17. Feb 15, 2022 at 1:48 PM
    Boco10
    ADK
    I would put that engine in a mint 93 4runner as a bucket item
  18. Feb 15, 2022 at 6:26 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    2JZ or nothing and don’t forget the NOS, buster.
    Edit: also consider the Gallo 12 or 24.
  19. Feb 16, 2022 at 2:50 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
  20. Feb 16, 2022 at 8:05 AM
    Radioactiv
    Radioactiv Well-Known Member
    Georgia
    2015 DCLB 4X4
    2nd for a 3.5L Eco boost, I've slowly been collecting parts to swap my 71 F100 over to one when I find the right donor truck
