Engine swap
Discussion in 'New Members' started by Isaiasv, Sep 13, 2023.
  1. Sep 13, 2023 at 3:43 PM
    Isaiasv
    Isaiasv [OP] New Member
    Isaias
    2006 Tacoma trd
    So the engine on my 2006 Tacoma went out and I found a good deal on an engine from a 2011 Tacoma there both the 4.0. If anyone has done anything like this how compatible are the two. Would i need to change out other parts
    buckhuntin-tacoma likes this.
  2. Sep 13, 2023 at 5:36 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  3. Sep 13, 2023 at 6:03 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Engine itself should be identical 05-11, 12-15 had different cylinder heads.
    You will need to transfer the engine harnesses from your engine to the replacement engine and I would also recommend using the sensors and injectors off your engine if they were in working order prior to it failing as well.
