Engine swaps are well known, but what about transmission swaps?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazytacoman, Mar 24, 2021.
  1. Mar 24, 2021 at 1:44 PM
    crazytacoman
    crazytacoman [OP] Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    Kind of a weird question, but I was thinking about how the automatic transmission on the double cabs really does the truck a disservice.
    anyone know of any successful transmission swaps that didn’t also involve an engine swap? If so, which transmission models?
  2. Mar 24, 2021 at 1:56 PM
    eon_blue
    Azusa, CA
    Like an auto to manual trans swap? Several on here have done it. Usually when they are converting a Prerunner to 4wd so they swap the trans too for the one they want.
    I haven't heard of anyone swapping out the auto for a different auto though unless it's just to replace a bad one with a good one of the same variety.
    crazytacoman[OP] and Abeyancer like this.
  3. Mar 24, 2021 at 2:23 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
  4. Mar 25, 2021 at 7:23 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    Yeah.. I was thinking of a swap from an automatic to another automatic. Was wondering if it would be do-able
    Wero94 likes this.
  5. Mar 25, 2021 at 7:34 PM
    eon_blue
    Azusa, CA
    I don't know of any other auto trans that will bolt up to the 3.4l at least not without fabrication or some kind of adapter
    If you do an engine swap too then you have those trans options
  6. Mar 25, 2021 at 7:36 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    True. Would be a cool thing to have. I wouldn't mind using an adapter so long as the price of the project is somewhat reasonable (like the price of doing an engine swap)
  7. Mar 25, 2021 at 7:45 PM
    Wulf
    Wulf no brain just damage
    rock raisin
  8. Mar 26, 2021 at 8:46 AM
    jbrandt
    Justin
    I'm not sure what the advantage of an auto to another auto would be. At least in a cost-benefit frame of mind... The autos really aren't that bad.
    In fact, the 340's are pretty damn solid transmissions.
    I have a doublecab with the auto, and really the only transmission I'd consider swapping is a 5 speed. I thought it might be cool to have the same transmission as what's in my 5th gen 4runner, as it's one of those auto-manuals, but *IF* I were to do that, I'd swap in the 4.0L as well, and bring all the ECU etc... along with it.
    But again, it comes down to cost-benefit... A LOT of cost, for not really all that much benefit besides being a cool engineering problem to tackle.
  9. Mar 27, 2021 at 11:19 AM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    Good points and gives me another perspective on the idea. Thanks! If I win the lottery one of these days, I'll do a build thread on this lol
    jbrandt[QUOTED] likes this.
  10. Mar 27, 2021 at 11:48 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The issue with using a different automatic most times is that it is computer controlled, and these days often controlled by the same ECU as the engine. Doing an automatic to manual swap will often times be much easier than doing automatic to automatic, unless you use a separate automatic transmission control unit.
    Long story short, yeah it's possible, but a lot of effort for not a huge change in drivability I'd say.
    Jeff
  11. Mar 27, 2021 at 12:07 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    It all depends on your budget but there's many companies that have adapters and flexplates available for a multitude of transmissions
    As for the A340 transmission that's in our trucks if built correctly these trans will support well over 1k hp and 20lbs of boost . The A340 is a very sought after set up for turbo'd 2JZ drag racing set up
    I've seen fully built drag racing Powerglides behind 3RZ's , 2JZ's even 3.4 V6's
    crazytacoman[OP] likes this.
  12. Mar 27, 2021 at 12:09 PM
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    Have you tried the TransGo Shift Kit? It's a cheap option with a fairly easy install that really improved the feel (and MPG!) of my 03 Xtra Cab.
    Wero94 and crazytacoman[OP] like this.
  13. Jan 5, 2024 at 12:52 AM
    Wero94
    Wero94 Well-Known Member
    2016 tacoma trd Sport double cab
    Would be a awesome to have a 10 speed transmisión on it
  14. Jan 5, 2024 at 1:13 AM
    Wero94
    In wish Tacoma did you Installed . Do you have the part number ?
