Engine tappet noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by damnfingers, Apr 8, 2014.
  1. Apr 18, 2014 at 8:07 AM
    #61
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I have an 8 yr, 100k mile comprehensive warranty. Mine is a little 'tappy' when cold but if there is an issue with it, I am hoping it shows up before 100k. :D
  2. Apr 23, 2014 at 2:13 PM
    #62
    damnfingers
    damnfingers [OP] Well-Known Member
    Gene
    Mississippi
    2016 Limited 2x4 DCSB
    Finally picked the truck up today and guess what....it's freaking QUIET!!!
    Here's what was written on the service sheet:
    "C/S there is a ticking noise in the engine. Sounds like a lifter. Happens all the time. Please check and advise. Removed left bank valve cover. Did not visually see any damage. Performed valve clearance check. Found cylinder 2 #2 intake valve with .0030 clearance. Removed all components to remove left bank cams. Removed #2 shim bucket lifter. Found excessive wear on top of valve and lifter. Removed all components to remove left cylinder head. Inspected valve guide. Found excessive clearance between valve and guide. Replaced left bank cylinder head. Both intake valves, springs and 1 lifter. Performed R&R valves from old head to new head and valve grind. Reinstalled all components."
    Part replacement concurs with above...I'm happy.
  3. Apr 23, 2014 at 2:26 PM
    #63
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Congrats, hope it stays that way. Can't believe it took them a week just to finish it though.
  4. Apr 23, 2014 at 5:51 PM
    #64
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Woot woot!
    BTW, Clifford's built stroker engine is the quietest 1GR I have heard yet. And I have spent a lot of time with the 1GR. Seems proper clearances make all the difference. ;)
