Engine temp gauge reading below normal when downshifting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by joncure, Jan 20, 2025.
  1. Jan 20, 2025 at 3:58 PM
    joncure
    joncure [OP] Well-Known Member
    VA
    2021 TRD Sport Access Cab manual
    When driving down a mountain in 3rd gear letting engine hold back the speed (engine braking), temp gauge goes down significantly below normal. I’d think temp would stay the same or maybe increase slightly.
    Is engine’s computer telling coolant system to increase flow or pressure thus cooling engine way down during this driving method?
  2. Jan 20, 2025 at 5:29 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    How far is significantly? Check coolant level in radiator and overflow. Thermostat could be stuck open. Fan clutch could be locked up.
    Thermostat should keep truck temp the same no matter what rpm or load for the most part.
    Clearwater Bill and Chew like this.
  3. Jan 20, 2025 at 5:39 PM
    joncure
    VA
    Interesting….
    I check coolant weekly. All good there.
    Significantly is gauge reads around 1st mark after C. Normal reading is close to midway on gauge.
  4. Jan 20, 2025 at 6:00 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    We have a variable lift thermostat.
  5. Jan 20, 2025 at 6:06 PM
    joncure
    VA
    Is that like a smart thermostat?
  6. Jan 20, 2025 at 6:24 PM
    Vlady
    Issy, WA
    There is a heater circuit that heats up the sensor at specific conditions to increase a flow to the radiator. Thus dropping the temp on the display.
  7. Jan 20, 2025 at 6:41 PM
    joncure
    VA
    Gotcha. That explains it pretty good. Thanks.
  8. Jan 21, 2025 at 2:47 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’m not sure why you are surprised the coolant temp drops during engine braking. Yes you are dissipating kinetic energy as heat, but you are also not burning any gasoline. I’m personally not sure what to expect, but I’m sure it would depend on a number of factors
    Phlogiston likes this.
  9. Jan 21, 2025 at 2:55 PM
    joncure
    VA
    If the engine’s running, it’s burning gasoline. As the engine is braking, the rpm’s are higher as the engine is working harder holding back the weight of the vehicle against gravity and inertia. The brakes are the only system here taking a break. Pun intended.
  10. Jan 21, 2025 at 2:58 PM
    gudujarlson
    Minnesota
    Not true, many modern fuel injected engines shut off fuel during deceleration.
    MOC221_, Kwikvette and Chew like this.
  11. Jan 21, 2025 at 2:59 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    All fuel injected engines cut fuel off on extended decel so nothing is being burned to create heat, the only heat being generated is a small amount from friction and compression.
    MOC221_, Chew and gudujarlson like this.
  12. Jan 21, 2025 at 2:59 PM
    joncure
    VA
    How does the engine run?
  13. Jan 21, 2025 at 3:04 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It's not running under it's own power on a decel, the wheels are still turning and the transmission is still engaged and thus keeping the engine coasting with the truck. Once engine speed drops back to near idle speed the fuel injectors are turned back on and it continues to run normally.
  14. Jan 21, 2025 at 3:04 PM
    gudujarlson
    Minnesota
    It’s being rotated by the wheels which are being rotated by gravity and/or momentum.
    MOC221_ likes this.
  15. Jan 21, 2025 at 3:09 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Its not running that's why you have engine braking. Try and turn your engine over by hand and you'll see how much resistance there is. That's whats happening with engine braking its just your tires are turning it instead of you.
    MOC221_ and Chew like this.
  16. Jan 21, 2025 at 3:10 PM
    joncure
    VA
    I’m learning something new today.
    gudujarlson likes this.
  17. Jan 21, 2025 at 3:15 PM
    gudujarlson
    Minnesota
    Unlike a carbureted engine, a fuel injected engine injects fuel into the engine independently of intake airflow. Thus it can shut it off when it wants.
    CAVEAT, the fuel injection controller takes air flow into consideration under “normal” conditions.
  18. Jan 21, 2025 at 3:26 PM
    joncure
    VA
    I just assumed as long as an engine is running, it’s sucking gas.
    Guess it shows that my other vehicle is a carbureted jeep.
  19. Jan 21, 2025 at 3:38 PM
    gudujarlson
    Minnesota
    Just to complete the thought, regardless of the fuel delivery mechanism, the engine is burning minimal fuel when engine braking.
  20. Jan 21, 2025 at 3:43 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Yes it's burning gasoline but significantly less during this process add in the increased airflow of cold air through the radiator and engine bay.
    I used to do this all the time with my Frontier except that it was a manual and i would put it in neutral and coast down mountain passes, the temp gauge would drop down pretty far.
