Engine Temp gets hot when towing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steveoh, May 15, 2012.
  1. May 15, 2012 at 6:30 PM
    steveoh
    steveoh [OP] Well-Known Member
    SLC
    08 ACLB SR5 4x4
    I have a 2008 tacoma access cab srs 6 cylinder 6 speed.
    I tow a small drift boat fishing on weekend trips and the truck will get pretty warm sometimes.
    It will never reach the red point, but it normally sits at 40%. When towing on the flats it seems fine stays around 40%. If I turn on the A/C it will shoot up to around 70% until I turn off the A/C.
    If I go up hill it will go up to around 80% and I dare not turn on the A/C when doing that.
    I can't imagine with two people in the car, the boat, and gear I'm adding more than 1500 pounds to the setup.
    I've never owned a truck before and the only time i've seen the temp sensor move is when I blew a head gasket so I'm not sure how normal this is.
    Please advise on things to do to keep the truck running for many more years.
  2. May 15, 2012 at 6:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The gauge is very vague. As long as the temps stasy below 220*, your fine.
  3. May 15, 2012 at 6:32 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Get a scanguage for your truck op so you can monitor the engine temp
  4. May 15, 2012 at 9:03 PM
    steveoh
    SLC
    08 ACLB SR5 4x4
    thanks, I just bought an ultra gauge. I'll come back when I have some real data.
  5. May 16, 2012 at 3:59 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Stock temp gauges are not very liner they aren't really hot until they are in the red zone this keeps people from freaking out when the temp really isn't that hot your new ultragauge will tell you the truth it gets it's info from the engine management system.
  6. May 16, 2012 at 6:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Actually, On many Tacomas, By the time the gauge hits the red zone, the engine is damaged.
  7. May 16, 2012 at 7:01 AM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    HHHMMMMMM My Taco routinely hits 215-225 while off-roading. Under any load I easily hit 200-205 (even doing 75 down the freeway). In heavy off-roading it holds at 220-ish but never gets over 225. I am boosted so that is part of it, I know I produce a ton more heat because of it. That is with using the scan gauge, even at that temp my gauge is just barely above the half way point.
  8. May 16, 2012 at 7:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ive hit the same temps, so I doubt being SC'd has anything to do with it.
  9. May 16, 2012 at 7:06 AM
    extremachn1
    Turd Furgison
    Tucson, AZ
    Ok, that does make me feel a bit better then. It must be an AZ thing then, because lets face it. ITS FUCKING HOT DOWN THERE.
    Do you run anything different coolant wide or just the straight Toyota pink coolant?
  10. May 16, 2012 at 7:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just the pink stuff from Toyota. Ive tried other addatives in the past, and never have seen any different results.
  11. May 16, 2012 at 7:11 AM
    extremachn1
    Turd Furgison
    Tucson, AZ
    I have tried changing to engine ice (although it takes a lot for a truck). It has worked on my Ducati's and MV Agusta in bringing the temps down on those because apparently italian engineers forget that the world gets warmer than 60 degrees outside. Those bikes are prone to setting parts on fire they get so hot.
  12. May 16, 2012 at 10:38 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DCSB SR5 V6 AT TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    That's odd. I tow a boat that probably weighs 5 times what yours weighs and my temp gauge never budges from normal even in triple digit air temps. I do have the tow package. That might be why.
  13. May 16, 2012 at 10:45 AM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Will an electric fan be the answer?
  14. May 16, 2012 at 10:47 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've towed much heavier than the OP and my temp gauge stayed right in the middle. I can get actual temps from a UG next time I tow. I do not have the tow package.
  15. May 16, 2012 at 10:49 AM
    extremachn1
    Turd Furgison
    Tucson, AZ
    Now do you just have the temp gauge or are you looking at something like a scan gauge? The temp needle barely moves until it gets REALLY hot but if you have a OBDII reader you can actually watch the temp. You might be running hotter than you realize towing a large boat in triple digit temps.
  16. May 16, 2012 at 11:34 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Just tossing here for comparison. I think highest temp I had seen on my scanguage was 196F. Normally it hovers 186-191F
  17. May 16, 2012 at 12:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its not as hot where you are.
  18. May 16, 2012 at 12:51 PM
    damnfingers
    damnfingers Well-Known Member
    Gene
    Mississippi
    2016 Limited 2x4 DCSB
    Trailer with a car...never overheats. Do you have the tow package?
  19. May 16, 2012 at 1:27 PM
    BlueT
    NorthEast
    True that's why I wrote just tossed numbers for comparison. ;)
    BTW Those temps are with tow package truck, Mobil 1 5W-30 + 0W-40
    You Running Mobil 1 as your oil right ?
  20. May 16, 2012 at 2:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, Im running Mobil 1
