Engine Temp gets hot when towing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steveoh, May 15, 2012.
  1. May 19, 2012 at 9:15 PM
    #41
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    Yea, I am looking at was to try to bring this temp down. Engine ice, electric pusher fans, cooler thermostat, etc. I already have a higher psi radiator cap. I also have a broken fan shroud I will be replacing when I get home as well.
  2. May 19, 2012 at 9:39 PM
    #42
    AllMountainToy
    AllMountainToy Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    Same here. I tow a 5000lb wakeboard boat in hot conditions and my needle doesn't move. I towed a 22' travel trailer without issue. Might be due to the tow package.
  3. May 19, 2012 at 9:46 PM
    #43
    extremachn1
    Turd Furgison
    Tucson, AZ
    No, its because the needle dosent move until you overheat. You temp is changing when you tow, you just don't notice it. We are basing out temps off using a scan gauge/ultra gauge to monitor actual coolant temp.
  4. May 19, 2012 at 9:50 PM
    #44
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Thankfully most of us use a 50/50 coolant mix in a self-pressurizing system. That combination pushes the boiling point to well over 250F.
    For what it's worth, the stock thermostat doesn't even crack open until 185F.
  5. May 19, 2012 at 11:03 PM
    #45
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    The shroud is a big deal.
  6. May 19, 2012 at 11:17 PM
    #46
    monkeyface
    Colorado
    Sounds like you're really pushing the engine to it's limit. Overheating happens when you do that, no big surprise.
  7. May 19, 2012 at 11:23 PM
    #47
    monkeyface
    Colorado
    extremach1 sounds like he's really pushing the motor to it's extreme.
  8. May 20, 2012 at 12:05 AM
    #48
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Yeah get an Ultragauge. Nice to have a digital temp readout. On the UG, I've never gotten over 194 degrees. 188 is my norm.
  9. May 20, 2012 at 2:52 AM
    #49
    extremachn1
    Turd Furgison
    Tucson, AZ
    Yea, I am hard on my engine, but also AZ has some pretty extreme temps. I do keep a close eye on it and having talked with others that have pushed there engines harder I seem to be ok. As long as the coolant system can keep the temp from going about 225-230 I should be fine.
    As for the shroud, its on my short list of things to fix as soon as I get back. I have the shroud, I just don't feel like pulling all my skids, fan, and other stuff out. I have to do it though or eventually pay the price.
  10. May 20, 2012 at 7:50 AM
    #50
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Few facts From FSM:
    Thermostat opens at 183F
    It's fully open at 203F
    So 212F does not sound too bad considering it's AZ and supercharged truck. I would think Tacoma can handle more than that. I am pretty sure Toyota coolant when new should be good until 265F so there is room.
    For those looking at highetened temps. Try washing radiator with soap and power washer to clean oily gunk that acts like insulator.
  11. May 20, 2012 at 7:52 AM
    #51
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    230* is the max temp an engine should get. Cooling ability dramaticly drops off after that temp, and the engine can over heat.
  12. May 20, 2012 at 8:32 AM
    #52
    extremachn1
    Turd Furgison
    Tucson, AZ
    Well it makes sense than if the thermostat isn't fully open until 212 and I sit at 220-225 under heavy offroading load than. Not saying I like it but... We will see once I get my shroud replaced and with my new high pressure radiator cap to see if it makes any difference.
  13. May 20, 2012 at 8:48 AM
    #53
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The radiator cap wont make a difference, unless the old one is blowing steam. The shroud will make the most difference though.
  14. May 20, 2012 at 8:59 AM
    #54
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    One problem with the Tacomas and towing is the fan. While it will work well with the ac off, the additional heat from the AC while towing will not be cooled off all that well with just the stock fan. Personally, I am going to put on an electric fan with thermostatic and AC switch activation. I am however debating on the layout, if I want to add 1 fan and keep the stock, or remove stock and add 2 (one that is thermostatic only and one that is thermostatic and ac switched. Which will have nominal HP and mileage gains as well from removal of the mechanical drag from the fan.)
  15. May 20, 2012 at 9:08 AM
    #55
    extremachn1
    Turd Furgison
    Tucson, AZ
    Ug, here we go again. Chris, keep your temper. LoL
    On the electric fan note, I have thought of doing a "pusher" style set up on the front of the radiator stack when offloading and towing in the heat. Not sure how well this would work if at all.
  16. May 20, 2012 at 9:36 AM
    #56
    hitmans.army
    Myrtle Creek, OR
    Lol. Mainly I just want to get rid of that dang pink spacer.
  17. May 20, 2012 at 10:03 AM
    #57
    joes06tacoma
    Joe
    Central Coast, CA
    Yep, if the dealer had to put the hitch on, OP does not have factory tow package. But he still shouldn't be having these problems with such a small boat in tow.
    Something's wrong. Is it overheating on the freeway? In town? We've had similar issues with my dad's Dodge Dakota.....in his case it turned out to be a clogged radiator. It could also be a lazy fan clutch (more noticeable in town, usually), bad water pump, etc.
    Toyota did not design this truck to run hot with a small load like that. Customers don't put up with it. Even without the tow package, you should be able to tow 3500 pounds without stressing over the temp gauge.
  18. May 20, 2012 at 10:46 AM
    #58
    BlueT
    NorthEast
    I recheck the bottle and actually working range for coolant is up to 265. My other number was wrong . So 230 may be boiling point on old coolant and bad cap. Otherwise 265 is absolute last number. You see 265 drive to junkyard
  19. May 20, 2012 at 11:32 AM
    #59
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A pusher would work well, provided we have the room. I had a pusher fan on my Dodge, and it kept it cool, even when working the hardest.
  20. May 20, 2012 at 11:53 AM
    #60
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Something is wrong... I have 1000lbs of tools in the bed of my truck at all times + camper shell and two ladders on top, A/C usually always on full blast (living in AZ) and I tow a single axle trailer 7x10 usually once or twice a week. Even with the trailer loaded with 1000 to 2000lbs my temp gauge never moves above normal...
