engine "tick,tap" at idle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by heliman79, Mar 4, 2015.
  1. Mar 4, 2015 at 4:56 PM
    heliman79
    heliman79 [OP] Well-Known Member
    Tim
    loxley al (baldwin county)
    05 sr5 prerunner v6
    is there a notorious "weak link" in the 4.0 v6? reason i ask is i cant seem to pin point my noise at idle, it almost sounds like a worn hydraulic timing chain tensioner( do these engines use them?) what is the suggested chain replacement mileage and whats involved? the engine doesnt seem affected at all by the noise, and it goes away past 1800 rpm. it doesnt sound like a wrist pin or bearing(i know that sound!)..its very faint but louder on warm, humid days like today. im running 5w30 oil, would a slightly heavier oil help? it doesnt knock or tap, tick at all at start up, but as soon as the engines comes to an idle i hear it. its most noticeable when the trans down shifts in to 1st when coming to a stop and then slowly accelerating. i know an engine with 130 k is going to make some valve train noise. are the lifters and cam followers known to go bad on these engines?
  2. Mar 4, 2015 at 6:50 PM
    heliman79
    Tim
    05 sr5 prerunner v6
    or is what im hearing the "taco tick"?
  3. Mar 4, 2015 at 6:52 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Embrace the tick
  4. Mar 4, 2015 at 6:56 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    taco tick..
    you can minimize it by isolating the evap valve on the side of the intake plenum.
  5. Mar 4, 2015 at 7:23 PM
    Bucc5207
    Bucc5207 Well-Known Member
    Yrisarri, NM
    2014 V6 SR5 4x4
  6. Apr 22, 2015 at 1:15 PM
    XStaco650
    XStaco650 New Member
    S/E USA
    '05 PreRunner TRD 2WD
    My wifes '05 Fourunner with 130,000 miles has had a ticking noise ( sounds like valve train or tappet noise) for some time. Seems to be coming from the left side,but having a tough time isolating it. Any help?
  7. Apr 22, 2015 at 4:21 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Live with it they do not have zero clearance hydraulic tappets it is a normal for all engines that have adjustable tappets.
  8. Apr 22, 2015 at 5:25 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Park your Tacoma on the other side of her.
  9. Apr 22, 2015 at 6:28 PM
    BlueMile
    BlueMile Frozen north specialist
    Patrick
    North/Central Alberta
    2009 TRD Sport
    ATV trail dents, many, many lights, 4-6 beer cans.
    You, I like you, might steal that one.
