Engine Ticking after oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rambler2005, May 14, 2020.
  1. May 14, 2020 at 10:41 PM
    Rambler2005
    Rambler2005 [OP] Well-Known Member
    Alex
    Wichita, Kansas
    2005 2Runner
    I took my 2005 V6 4runner to the dealership to get a oil change. I went on a cruise tonight with the windows down and heard this ticking noise. It only happens when I accelerate but it doesn't get louder it just get faster. I've replaced the ball joints on both sides and lower control arms on both sides. I didn't have a ticking noise before I took it to the dealership because I would have noticed it. They also removed the baling wire that I used to move the latch to open the hood so I have to make a new wire to check the oil tomorrow. If you would like a video I can send it through email as I don't know how to do it on here. If you have any ideas comment below. I'm calling them tomorrow if I don't figure out the issue myself.
    Thank you!
  2. May 14, 2020 at 10:50 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Whut??
    Rambler2005[OP] likes this.
  3. May 14, 2020 at 10:51 PM
    Rambler2005
    Alex
    Wichita, Kansas
    2005 2Runner
    yeah I'm super pissed off right now
  4. May 14, 2020 at 10:53 PM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Is there a rock in the treads of your tires?
    Rambler2005[OP] and TireFire like this.
  5. May 14, 2020 at 10:54 PM
    TireFire
    Olympic Peninsula
    I don’t understand why you can’t open your hood.
    I’m also puzzled that you can change ballpoints and lower control arms but not your own oil
  6. May 14, 2020 at 10:55 PM
    Rambler2005
    Alex
    Wichita, Kansas
    2005 2Runner
    already checked that but thank you
  7. May 14, 2020 at 10:56 PM
    Rambler2005
    Alex
    Wichita, Kansas
    2005 2Runner
    I had a friend help me with it and I have free oil changes through the dealership that's why I have it done there
  8. May 14, 2020 at 10:59 PM
    TireFire
    Olympic Peninsula
    There’s a lever under your dash to crack the hood ajar and then you stick ur fingers in the gap or thru holes in the grille
  9. May 14, 2020 at 11:01 PM
    Tyler7544
    Tyler7544 Well-Known Member
    L
    The most unique and special Tacoma
  10. May 14, 2020 at 11:02 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    It could be any number of things, from the standard 4.0L tick to a pebble in the wheel center cap to a wheel weight brushing against a caliper (they probably did a rotate / balance while servicing your truck), etc etc.
    Take it back to the shop and tell them about it.
    You could try running a search for “tick”, titles only, in 2nd Gen forum and browse those threads to see if anything jumps out:
    https://www.tacomaworld.com/search/11379920/?q=Tick&t=post&o=date&c[title_only]=1&c[node]=5
    Biscuits and Rambler2005[OP] like this.
