Engine "ticking" or "rattling"?
Discussion in 'Performance and Tuning' started by chris4x4, May 12, 2008.
  1. May 12, 2008 at 7:38 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  2. Jun 17, 2008 at 8:16 AM
    tacomaracing
    tacomaracing tacomaracing
    GEORGIA
    2005 toyota tacoma 2wd 2.7L
    AFE stage 2 intake,heavley ported throttle body,one of the gas buddys off ebay,fitch fuel catalyst,electric fan and relay kit,oil catch can,gibson exhaust,magnaflow catalytic converters and the spark plug non fouler no CEL light,wraped exhaust manifold,wideband o2(innovate),relocated IAT.
    i have a 2.7 and this works by the way:D
  3. Jun 17, 2008 at 10:33 AM
    MythotiK
    MythotiK Self Made...
    Just South of Hell...
    07 Silver TRD Sport AC
    DIY: Secondary Air Filter Removal, 3" Revtek Leveling Kit
    Wow...Sooo much better, thanks...:D
  4. Jun 19, 2008 at 10:57 AM
    BlueTaco
    BlueTaco Well-Known Member
    Long Beach, CA
    08 Tacoma Speedwayblue
    Nice, maybe this link could go under technical mods sticky?
  5. Jul 24, 2008 at 1:21 PM
    METROCO1
    METROCO1 Member
    06' TACOMA CREW CAB LONG BED SR5 TRD PKG
    I tried it on my 06' and it DIDN'T WORK at all still tappin it's A... off..................
  6. Jul 24, 2008 at 1:34 PM
    tacomaracing
    GEORGIA
    mine did it again this week too, water in the fuel, i have a water/fuel separator on order to fix it.... 40 bucks from summit,,,,, my injectors sound like a diesel:(:smash:
  7. Jul 27, 2008 at 12:34 PM
    tacomaracing
    GEORGIA
    i dont know--- im still working on it let you know tho....:crazy:
  8. Jul 28, 2008 at 10:59 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    Good thread Chris. This should be a stickey.
  9. Aug 4, 2008 at 8:53 AM
    tacomaracing
    GEORGIA
    turns out it was the hydraulic rocker bases on my 2.7 that was ticking. i used 5-40 (instead of 5-30)and a quart of Lucas synthetic oil treatment,,, that did the job.. keep in mind in i have rite at 100,000 miles,but its a Toyota// so hell i do not know what the deal is:confused:
    DID NOT WORK
  10. Aug 7, 2008 at 12:28 PM
    tacomaracing
    GEORGIA
    its the rocker lifters,$68 bucks each what the%*@!. why doesn't Toyota have a 100,000 warranty on new stuff..
    what i want to know is how in the hell do they collapse!!! know what i mean.:help:
  11. Aug 11, 2008 at 2:12 PM
    Jakub
    Jakub Member
    Denver, CO
    Stock
    I noticed the same problem occuring after my last oil change. It started after about 4k miles after I changed the oil.
    sympton:
    tick tick tick tick tick tick goes away for a few seconds and comes back to tick tick tick tick.
    This goes on to repeat itself.
    TacomaRacing- how did you find out that it was the rocker lifters. Does your ticking go away after you raise the RPM's? That is what mine does. It seems as soon as the oil starts flowing at a higher extent the ticking goes away.
    Take it easy,
    Jakub
  12. Aug 13, 2008 at 8:57 AM
    tacomaracing
    GEORGIA
    yes,the same thing i changed the oil with mobil1 0-20 this time again(4 days ago) it help a lot but still does it a little. the rocker lifters have to be submerged in oil and mines not doing that,I'm trying to find some type of oil filter restricter to bump the oil pressure up 10 more pounds or a different brand oil filter. (i use the OEM filter)
    what model is your truck
  13. Aug 13, 2008 at 9:09 AM
    Jakub
    Jakub Member
    Denver, CO
    Stock
    Well I can't find the PWM on the 2.7L.
    Anyone???
    I am more convinced that it is the rockers. They need to be filled with oil to actuate correctly, sometimes they do not fill with oil so the chamberis empty and the noise occurs.
    I am going to tear into mine the next day or two if I cannot find the valve that they are talking about on the 4.0L models.
    2005 2WD 2.7 Access Cab fully stock. Ran 5-30 mobil from day one.
    Would the PWM valve only operate when its warm. My problem only occurs when the truck is warmed up. Which leads me to the rockers because of the oil change in temp.
    Anyone?
  14. Aug 13, 2008 at 9:18 AM
    tacomaracing
    GEORGIA
    mine is all the damn time.its the quitest at start up!!!!!:crazy:
  15. Aug 13, 2008 at 1:56 PM
    tacomaracing
    GEORGIA
    here you are , i have already tryed..., it didn't change anything:laser:
  16. Oct 7, 2008 at 11:10 PM
    UNHAPPY GREG
    UNHAPPY GREG New Member
    mt. aukum ca
    06 tacoma trd sport
    The valve noise in my P.O.S. is the same if not worse than it was after 2500 mi.Toyota tell's me it's normal I think not!!!. I hope they get their #%*$$ together.UNHAPPY GREG with a P.O.S 2006 tacoma trd sport.
    P.S
    I just turned 30,000 MI.
    can i get some help with this thank's Greg
  17. Oct 8, 2008 at 11:02 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    Good find Chris
  18. Oct 13, 2008 at 12:02 PM
    hardin083
    hardin083 Well-Known Member
    Florida
    08 Prerunner SR5
    MODS: 3" EZ lift with 1.5" rear blocks,blacked out emblems,belt chime mod,20%tint job,driveline vibration TSB done,harsh ride TSB,285/75/16 nitto terra grapplers,EGR in channel window visors/future mods:seat covers, blacked out rims.
    tried this on my 08 4.0L and it doesn't seem to help any!!
  19. Aug 26, 2009 at 8:13 AM
    Jakub
    Jakub Member
    Denver, CO
    Stock
    Hello, since about 80,000 miles I have been fighting this tick.
    http://s81.photobucket.com/albums/j225/usadaytrader/?action=view&current=MVI_6360.flv this was posted by another guy on the web that had the same issue
    I finally just ran som SeaFoam thru it and the problem is gone.
    I have been told it was a bad lifter by toyota and it would need to be replaced as well as by other mechanics. It must have just been stuck.
    The tick would usually be louder after along trip and stop above 2700rpm, or just go away.
    Later on,
    Jakub
    CowboyTaco likes this.
  20. Aug 26, 2009 at 10:21 AM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    I'll have to try this. :cool:
