Engine Timing / Front Cover Replaced
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joneswm99, Apr 12, 2019.
  1. Apr 12, 2019 at 12:44 PM
    Joneswm99
    Joneswm99 [OP] New Member
    Looking at buying 2016 Tacoma with 59,000 miles. Carfax shows “engine timing / front cover replaced” by local dealer shortly after vehicle was acquired at auction. I have read about what this repair involved. Truck price is good but only a little less than comps in the area. Should this completed repair make me not want to buy this Tacoma?
  2. Apr 12, 2019 at 12:48 PM
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    How much for this gem?
    Joneswm99[OP] likes this.
  3. Apr 12, 2019 at 12:48 PM
    adamant365
    adamant365 Well-Known Member
    Adam
    Kentucky
    '09 SR5, DCSB, 4x4
    My 09 had a leaking timing cover when I bought it at 45xxx miles. They fixed it under warranty. No leaks or issues since. 116xxx miles now. I suspect what they actually did on the one you're looking at was change the timing cover gasket, not the cover itself.
    I wouldn't worry about that. Just make sure there's no sign of leaks now.
  4. Apr 12, 2019 at 12:51 PM
    Joneswm99
    Trying to buy this for around $22k. It’s a 2WD SR5 package V6.
  5. Apr 12, 2019 at 6:07 PM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    Buy a 4wd, higher resale...
    Joneswm99[QUOTED][OP] likes this.
  6. Apr 12, 2019 at 6:12 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    A leaking timing cover does not indicate a defective engine or abuse of the engine. Of the gaskets that could fail, it is the least problem as it just lets a drip of oil out of the engine, and does not involve mixing coolant and oil or vice-versa.
    If the leak is fixed I wouldn’t worry about it at all.
    whatstcp and Joneswm99[OP] like this.
