Engine. To wash or not to wash?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by In2Ndo, Mar 30, 2018.
  1. Mar 30, 2018 at 3:16 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  2. Mar 30, 2018 at 3:17 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    I wash my engine every time I wash the truck and use the high pressure wand at the car wash and at home with little regard of what I'm washing. I've been doing this on my15 Camry, my traded in 12 Taco and now my 18 Taco. I have never had an issue.
  3. Mar 30, 2018 at 3:18 PM
    STPJ07
    STPJ07 Well-Known Member
    Florida
    2017 OR TRD 4x4
    Hmph.
    I think it's the "already a hot taco" part that threw me off.
    Never mind.
    Carry on. :pccoffee:
  4. Mar 30, 2018 at 4:32 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Yup- camping and living in the country where rodents frequent my engine compartment made me give up trying to have a sparkly engine - rodent repelling is a priority, because there’s no way to keep them out. I do wash it with a diluted solution of simple green as mentioned above, then put pepper on it.
    tcjacado, ChadsPride and James_Bond like this.
  5. Mar 30, 2018 at 5:28 PM
    TTtaco
    TTtaco Well-Known Member
    I am 58 and have washed just about every vehicle's engine bay that I have ever owned at the car wash!
    And will continue to do so.
    Beerpayzdabillz likes this.
  6. Mar 30, 2018 at 5:36 PM
    CleanWilly
    CleanWilly Well-Known Member
    2017 Access Cab Offroad
    Dow Bathroom Cleanser, you know, the scrubbing bubbles type, works really well. Spray on warm not hot engine, let sit for 15 mins, hose off.
  7. Apr 2, 2018 at 5:28 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    One thing I'm leary of is spraying the battery and getting acid overspray residue on the paint. I wipe mine down.
  8. Apr 2, 2018 at 6:59 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    If your battery is leaking acid it needs to be replaced and not left in the truck. Its a serious safety hazard and means the battery is damaged.
    The “leaking” that leads to most of the corrosion around the terminals is gaseous leak not liquid. Its hydrogen gas leaking out of the battery.
  9. Apr 2, 2018 at 7:24 AM
    2016Tacoman
    J
    It doesn't have to leak. Look at the corrosion on the terminals. It even can burn a cut on your hand.
  10. Apr 2, 2018 at 7:39 AM
    PackCon
    Connor
    Battery acid is inside the battery. If it’s on the outside it means the battery has broken and it’s leaking highly caustic flammable liquid all over. So yes, if acid is coming out there is a leak and you need to remove and dispose of the battert right away.
    Common corrosion is caused by gas leaking out of the terminal not battery acid.
    You should keep the battery clean and free from corrosion.
  11. Apr 2, 2018 at 8:04 AM
    2016Tacoman
    J
    I use a mixture of baking soda to neutralize the acidic copper sulfate from the hydrogen gas and wipe it. I do not spray it away to contaminate adjacent surfaces for obvious reasons.
    Most all batteries have this and it's not a sign it needs to be replaced asap.
  12. Apr 2, 2018 at 8:19 AM
    srcarder
    srcarder Member
    2017 TRD OR DCSB
    I have used the pressure washer at the car wash for the last 20 years on all of my vehicles and never had an issue (I only clean the engine bay 3-4 times a year). I am somewhat careful but I do not cover anything in advance.
    PackCon likes this.
  13. Apr 2, 2018 at 8:22 AM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    The baking soda mixture will indeed temperately clean and neutralize white acid residue around your battery terminals, but today's batteries should not be producing this as it is an indication there is a leak around the terminal. Without the slightest hesitation, Toyota warranty replaced a 2 year old battery in my 2012 Tacoma because of this. The original battery had a 36 month warranty if I recall correctly and of course when they put the new one in, the warranty clock reverts back to the original battery date, so just 12 months on it. That truck has been traded in at this point, but I keep an eye on the battery of my new 2018. If I see any acid build up, I'll request a replacement.
    PackCon likes this.
  14. Apr 2, 2018 at 8:32 AM
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    I like a clean and tidy engine compartment. When I have time I usually use a rag and 409 to clean up the engine cover, hoses etc. Maybe once a year or so, I'll do the full blown clean up using some simple green/water followed by light brushing the stubborn areas like the groves in the air hoses and such then a good rinse off with a hose and a final wipe-down clean up. I don't mask components off but I am conscious the electronics and delicate areas, and always let the engine cool an hour or so if it had been running.
    PackCon likes this.
  15. Apr 2, 2018 at 5:33 PM
    #35
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    Ive dried out a few distributors in my younger years. While at car wash.
  16. Apr 2, 2018 at 6:18 PM
    #36
    rdjr17
    rdjr17 Well-Known Member
    Ron
    Nepa
    2019 voodoo blue Trd pro
    I do same set up but with pressure washer , but just go light with the pressure , it rinses quicker with less water than a hose . Biggest thing is with any chemical always do on cold engine . cover alternater and avoid hitting electronics, after rinsing everything I let truck sit for 15 running then go for a drive to let the engine dry itself out never had a issue doing it that way .
    boynoyce[QUOTED] likes this.
