Engine tranny separation
Discussion in '1st Gen. Tacomas (1995-2004)' started by My3rdTac, Jun 30, 2011.
  1. Jun 30, 2011 at 10:04 PM
    My3rdTac
    My3rdTac [OP] Member
    Markus
    Denver
    02 2.7L Xtra Cab SR5
    Mostly Stock
    I've got a 2002 Tacoma Xtra Cab 2.7L SR5 automatic with 150,000 miles on it. Last weekend my engine shot a rod.
    I've got the engine almost ready to be pulled, but have a question about how to pull it. I'd like to leave the transmission in the truck, but am unsure of the procedure.
    Can I simply unbolt the motor from the transmission, slide it forward and lift it out? Do I need to do anything to the driveline? (transmission, t-case, shafts??)
    Any help would be appreciated.
    Thanks,
    Markus
  2. Jun 30, 2011 at 10:09 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Just undo the belhousing bolts and you should be good to go. It will slide right out.
  3. Jun 30, 2011 at 10:21 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    use a jack to support the front of the tranny
    other than that your good to go
  4. Jul 1, 2011 at 2:03 AM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    Is it auto or 5 spd? If it is auto you want to take the torq converter bolts or nuts out to avoid binding on the front pump and seal.
  5. Jul 1, 2011 at 5:40 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    ^this^
    It might be a little difficult with a thrown rod though.
  6. Jul 1, 2011 at 9:17 AM
    My3rdTac
    Markus
    Denver
    Mostly Stock
    It's an automatic. Where are the torque converter bolts? What do I need to worry about for the reinstall?
  7. Jul 1, 2011 at 9:20 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    They are on the fly wheel. You should have a small sheet metal plate where the tranny meets the motor. You should be able to access them there. The only issue is turning the motor. I don't know how much of an issue the thrown rod is going to give you.
  8. Jul 1, 2011 at 9:23 AM
    My3rdTac
    Markus
    Denver
    Mostly Stock
    I know where that is, why would I have to turn the engine, to access the bolts? Engine still runs, it just sounds terrible, so I should be able to spin the crankshaft.
  9. Jul 1, 2011 at 9:31 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Because the bolts are around the perimeter of the fly wheel. Yes, spin the crankshaft bolt by hand (socket).
  10. Jul 1, 2011 at 12:27 PM
    My3rdTac
    Markus
    Denver
    Mostly Stock
    Great, That is good to know. Any tricks when I'm dropping the new motor in?
  11. Jul 1, 2011 at 12:36 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Take it slow and have two spotters. Replace the torque converter with new or rebuilt, put fluid in it and lube the seals with trans fluid.
  12. Jul 1, 2011 at 12:38 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I don't remember if the seals are on the input shaft or not, but replace them if they are.
  13. Jul 1, 2011 at 12:50 PM
    My3rdTac
    Markus
    Denver
    Mostly Stock
    How hard is swapping out the TC? A new TC is 1,000 bucks. I think i'll just do the seals and clean everything out
  14. Jul 3, 2011 at 3:34 PM
    donaldwagner
    donaldwagner -Don-
    Donald
    College Park, Orlando
    2013 single cab 4x4
    ha! my lower end went out and i couldnt get the damn engine apart from the tranny, i pulled both. ive heard you gotta push that tranny up and down rapidly to get it to separte from a buddy of mine that worked at toyota. just a heads up
  15. Jul 5, 2011 at 9:52 AM
    My3rdTac
    Markus
    Denver
    Mostly Stock
    Engine separated and came out with no problems. I get the new engine tomorrow, and new Torque Converter Seals tomorrow. I'll post some pictures when I'm done
  16. Jul 5, 2011 at 10:13 AM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    Sorry to change subject but, what causes a shot rod?
  17. Jul 5, 2011 at 10:33 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    No or low oil pressure. Oil is critical! Overheating will cause a breakdown of the oil and yeild the same result.
  18. Jul 5, 2011 at 2:21 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Hydrolocking can also cause it :eek:
  19. Jul 5, 2011 at 2:36 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Ouch! Yea, that's the fun way. The others are slightly less obvious:)
  20. Jul 11, 2011 at 11:49 AM
    My3rdTac
    Markus
    Denver
    Mostly Stock
    Separation went great, having some trouble getting them docked. Any tricks or suggestions? I'm very close 3/8 of an inch from everything sliding together.
    Also, this project just got a little more expensive, cracked my head on the cherry picker, a quick trip to urgent care, a couple hundred dollars and I've been glued back together.
