Engine & Transmission Oil Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mquibble, Feb 15, 2021.
  1. Feb 15, 2021 at 7:57 PM
    mquibble
    mquibble [OP] Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I’d like to hear from all you experienced DIYers here about my maintenance plan. I have a new 2021 Pro and will be changing all my oils at 1,000 miles for the break-in period [eng, Tran, transfer, diffs].
    I also plan change intervals to be sooner than recommended. As an example, my plan is to change tranny fluid at 1k, 20k, 50k, 80k, etc and to offline filter the fluid every 5k miles using a bypass filter of 2 microns with a bench and pump setup.
    I will likely do this for the engine oil with a second bench top bypass setup. Using Amsoil signature series and filter so I will drain the fluid every 5k miles through an easy Fumoto valve to pass it through its own 2 micron before reintroducing it back into the block.
    The extra cost isn’t unreasonable and the effort won’t be bad either. I’ve always been one who takes their oil regimen fairly seriously but I think I’m ready to step up my game just a little bit more. Interested to hear from others who might have their own OCD oil regimens.
    DAS Taco and skiploder like this.
  2. Feb 15, 2021 at 8:07 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Wow, and I thought I was particular... :crazy:
    Me thinks you're over thinking it a bit.
    I use Amsoil as well and change every 10k.
    I use 20w40 and 1 quart of Marvel Mystery Oil.
    I use Redline MT90 with a little Lucas in the trans but I'm manual.
    Skydvrr, DAS Taco, Kev250R and 2 others like this.
  3. Feb 15, 2021 at 8:14 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Overkill. I just did my rear diff at 42K and the drain plug was clean.
    kgilly, bryflies and Key-Rei like this.
  4. Feb 15, 2021 at 8:17 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    That's a lot of extra time and money for no appreciable benefit.
  5. Feb 15, 2021 at 8:19 PM
    Bishop84
    Bishop84 Well-Known Member
    Wild overkill. Flushing money down the oil drain.
    Change engine oil every 5k with quality oil. It's not a porsche that sits.
    Transmission won't benefit from such frequent changes. I'd stick to every 30k
    The hammer, kgilly and bryflies like this.
  6. Feb 15, 2021 at 8:24 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Sorry Buddy... but we've all been brought up being told frequent oil changes will prolong engine life... and it's bull. I've worked in three dealerships and seen mechanics there recommend 3K oil changes... and they take the oil they drain and put it in their own vehicles.
    A 1K break in period won't be enough to break in a vehicle. The whole point of a break in period is to seat the piston rings and that requires some slight wear.
    I've bought vehicles with engine knocks from never having the oil changed, changing it and putting tranny fluid in to flush the gunk, and eventually the engine quiets and runs great... selling the vehicles years later and running fine.
    If it makes you feel good... do whatever you feel is right. But for my money I'll follow the recommends in the owner's manual.
    Jim1946 likes this.
  7. Feb 16, 2021 at 2:02 AM
    verlaryder
    verlaryder Well-Known Member
    Overkill. The 500,000 - 1,000,000 miles without a drivetrain componet overhaul owners don't do what you are planning to do. They give equal preventive maintenance attention to ALL engine systems; ignition, fuel, cooling, emission. And don't mod anything or use aftermarket parts like special tranny filters.
    Here's a 2007 Tundra 2UZ-FE V8 owner who went 1,000,000 miles on 5W-30 conventional oil changed by a dealership every 10,000 miles using Toyota filters and the tranny lasted 730,000 (and only reverse gear went out) http://www.trucktrend.com/how-to/project-trucks/1705-million-mile-tundra-the-tear-down/
    DAS Taco, kgilly and Travlr like this.
  8. Feb 16, 2021 at 2:21 AM
    OverlandExpress
    OverlandExpress Well-Known Member
    NE Ohio
    2020 Taco TRD PRO
    waste of time and resources...
    kgilly likes this.
  9. Feb 16, 2021 at 2:27 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  10. Feb 16, 2021 at 4:11 AM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Lol, touche’.
    Plain Jane Taco likes this.
  11. Feb 16, 2021 at 4:34 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    1k is good for the first engine & rear end oil change, but the rest of the fluids would be fine if you just cut the Toyota recommended times/miles in half.
    PayneAutos likes this.
  12. Feb 16, 2021 at 5:28 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Imo, doing your first oil/filter change at 5k miles...transmission, front and rear differentials and transfer case at 30k miles is more than good.
    The hammer likes this.
  13. Feb 16, 2021 at 5:37 AM
    mquibble
    Michael
    2021 TacomaTRD Pro
    I very much appreciate everyone’s opinions. Your help isn’t being lost on me. I value your knowledge and experience you all are sharing unselfishly with me.
  14. Feb 16, 2021 at 5:56 AM
    Plain Jane Taco
    USA
    Old wive's tail. And has never been true.
    OP....you're factory fill is synthetic. Keep using it
    Kev250R, kgilly and hiPSI like this.
  15. Feb 16, 2021 at 5:58 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol 2 micron. They don't even filter beer to 2 micron! Bacteria is 3-5 microns. If you filter to 2 micron you will be filtering out all of the oil additives, But apparently you are an amsoil disciple so really... who cares what you do? You do you buddy. Good luck on that 2 micron filtering and google is your friend...
    The hammer, Junkhead and DAS Taco like this.
  16. Feb 16, 2021 at 5:59 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Wow...
    The hammer and Plain Jane Taco like this.
  17. Feb 16, 2021 at 6:00 AM
    bishtaco
    bishtaco Well-Known Member
    Virginia
    2013 TACOMA BASE TRD OR
    I just did my transmission, transfer case, front and rear diff at 8 years and 27k miles. Follow the manual and you will be ok.
    Plain Jane Taco and kgilly like this.
  18. Feb 16, 2021 at 6:01 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    changed my initial oil at 1500 then every 5-6000 after that. changed my differentials & transfer at 50k, tranny is good for 100k.. never did anything like your schedule for over 30 cars/trucks i have owned and never had issues..
    save your money and time and put it to better use.. drive it and enjoy it..
  19. Feb 16, 2021 at 6:02 AM
    Clearwater Bill
    Billy
    Largo Florida
    And they'll be fine if you follow the recommendations too.
    Travlr and Plain Jane Taco like this.
  20. Feb 16, 2021 at 6:02 AM
    kgilly
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    it comes with synthetic...
    DAS Taco and Clearwater Bill like this.
