Engine & Transmission Oil Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mquibble, Feb 15, 2021.
  1. Feb 16, 2021 at 8:00 AM
    #41
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Good lord. You're going to spend way more to do the maintenance than you'd spend just driving it till parts break and then replace them. I've had my 2007 going on 14 years and 210,000 miles. I change the oil every 10K or once/year whichever comes 1st. I used to drive it 20,000-25,000 miles/year, but closer to 10,000/year now.
    It still has the factory transmission fluid in it and I'll change that fluid when, or if I have the transmission rebuilt. The factory fluid should be good for at least 400,000 miles and at the rate I'm driving it that will be another 20 years. Changing the fluid as often as you say will literally cost more than having the transmission rebuilt and it won't last any longer.
  2. Feb 16, 2021 at 8:01 AM
    #42
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    lolo! Toyotas in Africa or Middle East burn so much oil from the lack of oil changes, they don't need to be changed.
    Hooper89 likes this.
  3. Feb 16, 2021 at 8:11 AM
    #43
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    OK NOW I am subscribed to see if someone recommends a Snickers bar
  4. Feb 16, 2021 at 8:14 AM
    #44
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Because the amount of EP (extreme pressure) contact and lubricant volume (I suppose you could call it a ratio) - there will be more wear metals early to get rid of (early) and enhance bearing life. Of course differentials in Africa last billions of miles with no fluid, so even this is overkill, just more justified than other overkill.
  5. Feb 16, 2021 at 8:15 AM
    #45
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    OP stick with the filter/oil change every 5k, trans and diff every 30k unless you plain on towing a lot, then adjust.
  6. Feb 16, 2021 at 8:19 AM
    #46
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    African bearings are strong lol
    Pablo8[QUOTED] likes this.
  7. Feb 16, 2021 at 8:30 AM
    #47
    Brianz1001
    Brian
    too much to type
    Stick with what you like, I’ve turned wrenches for over 40 years. I’m sticking with the 5k rule, do 10k if you want. I guarantee if we cracked both engines open at the same time and mileage the 5k would be cleaner. OP sounds like he is finicky about his ride so 5k would fit his needs. But it is your ride so follow what you want.
    fyi.. for the cost of your oil analyses, I would rather do an oil change. Hey but that me. Do what makes you happy.
    Junkhead and The hammer like this.
  8. Feb 16, 2021 at 8:31 AM
    #48
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    what brand..............i see U mentioned amsoil ( didnt know they made a 2 micron retail )
    where do U obtain a 2 micron filter
    best iv seen 5micron
  9. Feb 16, 2021 at 8:35 AM
    #49
    ryanvar42
    None
    best place is ebay. They have them easy to find.
    #49
  10. Feb 16, 2021 at 8:46 AM
    #50
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Serious over-kill and a waste of time and $.
    I change oil and filter in my 2018 TRD Sport at 5,000 miles (not the recommended 10,000) as I've always changed my '96 Tacoma at 5,000 miles and it has 414,000 trouble-free miles on it and has never had an engine cover off.
    Now as far as fluids go, no need to change them more than Toyota recommended intervals if even then. My '96 is 25 years old with 414,000 miles and still has the original 5-speed manual trans oil and it shifts as smooth and quite as when new.
  11. Feb 16, 2021 at 8:51 AM
    #51
    ryanvar42
    None
    exactly, the engineers are Toyota I am pretty sure know what they are doing...…..
  12. Feb 16, 2021 at 8:55 AM
    #52
    Brianz1001
    Brian
    too much to type
    Not really, OP asked for options, that’s my recommendation. Do yours at 10k I really don’t care. Please go turn wrenches for 40+ years professionally then come talk to me not as an fyi’er but as a professional mechanic. It’s your truck do what you want.
  13. Feb 16, 2021 at 8:58 AM
    #53
    The hammer
    Hm...Really...Ever hear of Takata air bags?
    Brianz1001 likes this.
  14. Feb 16, 2021 at 9:00 AM
    #54
    The hammer
    With all the funny stuff out the way, I see you want to take care of your machine so I’m here to help.
    I see no mention of the air filter here. This is another way dirt and contaminants find their way into your engine. That said, particles in the 10-20 micron range can cause the most damage and wear to an engine.
    Also I see no mention of the lowly PCV valve.
    I change mine every two years or 20k. This valve maybe spring loaded with small passages that can get clogged and become restrictive to flow and can fail due to fatigue or just plain fail without much notice so I change it.
    Replacement It’s not even mention in most manuals anymore for replacement but I change it, so go figure, I really maybe alone and overkill here, but que sera sera!
  15. Feb 16, 2021 at 9:00 AM
    #55
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Ditto sludged Toy V6's
    The hammer[QUOTED] likes this.
  16. Feb 16, 2021 at 9:00 AM
    #56
    Brianz1001
    Brian
    too much to type
    Don’t forget about those awesome frames they been putting out for years also.
  17. Feb 16, 2021 at 9:04 AM
    #57
    The hammer
    Oh yes, how clumsy of me :D
  18. Feb 16, 2021 at 9:05 AM
    #58
    Brianz1001
    Brian
    too much to type
    Don’t blame me, I’m an engineer and I know what I’m doing.
  19. Feb 16, 2021 at 9:08 AM
    #59
    Brianz1001
    Brian
    too much to type
    Vbpiper do what you like, it’s your truck. But I bet your frame will fail way before you will see an issue with your oil. Sorry to say but that’s fact.
  20. Feb 16, 2021 at 9:14 AM
    #60
    The hammer
    Oh no not you, you're the good!
    Brianz1001[QUOTED] likes this.
