engine upgrade?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BrianPK, Mar 30, 2007.
  1. Mar 30, 2007 at 12:37 AM
    BrianPK
    BrianPK [OP] Offroad Enthusiast
    Modesto, California
    01 TRD 4WD V6 SR5
    CB Radio, 3'' fabtec spacer lift and 3'' body lift flowmaster dual exhaust, deckplate mod, silencer mod, Work in progress pioneer 7900bt stereo with 5X8 infinity speakers all around, and eclipse ex400 amp
    anyone know if you can swap out the stock 3.4l for the newer 4.0l engine in an 01?
  2. Mar 30, 2007 at 12:23 PM
    MarkC
    MarkC Carolina Alliance: Warheads On Foreheads Division
    Mark
    Yokota AB, Fussa-Shi, Japan
    99 4x4 SR5
    2 inch spacer in the front, and homemade add a leaf in the rear, billet grille, bull bar
    you can put anything in there with enough time, money and wiring skills
  3. Apr 1, 2007 at 12:27 AM
    BrianPK
    Modesto, California
    01 TRD 4WD V6 SR5
    well, what i meant was, how "easy" would it be to drop the 4.0l into my 01?
  4. Apr 1, 2007 at 9:03 AM
    MarkC
    Mark
    99 4x4 SR5
    u would probaly have to fab engine mounts, relocate componates like washer res. and brake lines, cut and hack the wiring harness, then swap trannys or make a custom bell housing for the old one. so in short, not easy at all... it'd be cool as shit to see a 4.0 in a 1st gen. tho!
  5. Apr 1, 2007 at 2:29 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    A bit more work and money that its worth. You've got the engine, trans, ecu and wiring and shortening of the drive shaft. Your better off just getting an 05 and up.
  6. Apr 4, 2007 at 2:04 PM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Why do want to get rid of the 3.4 motor? If you are looking to gain more hp out of the 3.4 consider supercharging the 3.4. Less money and less fab time.
  7. Apr 5, 2007 at 3:40 AM
    BrianPK
    Modesto, California
    01 TRD 4WD V6 SR5
    I'll be honest with you... i was considering the 4.0L AND the supercharger. i'm just looking to build something a little different.
    curious to see what's possible!
  8. Jul 27, 2007 at 12:31 PM
    scuzz
    scuzz Member
    Just drop a LS1 in if you're going to be doing all that fabrication.
