Engine upgrades
Discussion in 'Performance and Tuning' started by tacotruck2005, Nov 28, 2018.
  1. Nov 28, 2018 at 3:12 PM
    tacotruck2005
    tacotruck2005 [OP] Goodolboys 4x4 section
    Bozeman Mt
    Any suggestions for the best way to upgrade 4.0 liter v6 2005 tacoma's engine. I know the engine is great, durable, and "shouldn't be modded" but I need to go fast and I need the power to climb. I'm also a college student so I don't have a blank check.
  2. Nov 28, 2018 at 3:22 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    A engine is basically a big air pump so if you can get the air into the cylinders and out the tail pipe as quickly as you can you'll make more hp and tq
    To get the air into the motor you would need a good filter and not have no obstructions getting airflow into the throttle body
    To get the air out of the motor you would need a header (s) preferably a Tri Y design as this helps scavenge the exh out quicker and stops exh pulse reversion . Next would be a good flowing Cat back set up
    You're looking at a possible 15-20hp gain !!
  3. Nov 28, 2018 at 3:28 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    boost. a lot of boost.
  4. Nov 28, 2018 at 5:32 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    You gotta pay to play.
    As far as "fast" u need to get the ucon from urdusa.com, otherwise the governor will always stop u from going much beyond 110/115
    Don't ask how to disable the governor here, thread will get locked.
    As for "quick" u have many options.. forced induction, stroker kit, headers, ypipe, exhaust, ucon, maybe ovtune, turbo if ur able to Fab yourself.
  5. Nov 28, 2018 at 5:34 PM
    inwood customs
    Dave
    Give us a budget, otherwise youre limiting us
  6. Feb 24, 2019 at 4:01 PM
    Globaldriver63
    Globaldriver63 Well-Known Member
    David
    Upstate SC
    I'm hearing the bullydog programmer is good, anyone have HP numbers?
  7. Feb 24, 2019 at 5:14 PM
    inwood customs
    Dave
    Who said it was "good"?
    Id ask them to back that statement with numbers.
  8. Mar 1, 2019 at 6:14 AM
    Globaldriver63
    David
    Upstate SC
    If the Bully Dog is not a good tuner, do you have a recomendation?
