Engine vibrates/idles at 750-800
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gr8tacsprt10, May 21, 2019.
  1. May 21, 2019 at 3:52 PM
    gr8tacsprt10
    gr8tacsprt10 [OP] Well-Known Member
    Vince
    Kirtland AFB, New Mexico
    I've done research on why these 4.0’s vibrate on low idle, so I cleaned my TB/MAF sensor/removed the secondary screen last weekend .. still no luck. I rate is not too bad where it engine dies.
    2010 tacoma sport
    No codes
    No misfires
    Has 109,603
    Tune up was done at toyota @ 103,909
    I’ll try to replace my spark plugs this weekend, if that don’t work I’ll borrow a scanner at work and see if any of the injectors are acting funny.
    Any inputs would be appreciated.
  2. May 21, 2019 at 3:54 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    What year?
  3. May 21, 2019 at 4:01 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I just read a thread today about a 2nd Gen with vibration issues and the OP used BG44 treatment and said that so far after that, issue seemed resolved. Might be worth giving that a try.
    gr8tacsprt10[OP] likes this.
  4. May 21, 2019 at 4:45 PM
    gr8tacsprt10
    Vince
    2010
  5. May 21, 2019 at 4:52 PM
    TacomoMoto
    TacomoMoto Well-Known Member
    Miami
    09 SR5 Sport 6speed 4.0L
    Have you tried cleaning your throttle body ? My 4.0 was idling low and shaking I cleaned the throttle body and good as new !!
  6. May 22, 2019 at 9:50 AM
    taco912
    taco912 Well-Known Member
    North of the Bridge
    2006 AC 4.0 AT 4x4 SR5 TRD OR
    I have been running a large bottle of Techron concentrate, not the Fuel Injector cleaner, once a year through all of my FI cars for years (Euro sport cars, trucks, everything). I have notice the difference at idle several times. I'm pretty sensitive to how my vehicles run and often can tell if a CEL is going to pop before it happens. It scavenges out any moisture and cleans up injectors.
    Obviously make sure your tune-up is good.
  7. May 22, 2019 at 9:58 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Any fuel system cleaner with p.e.a is good. I run Amsoil PI every three months or so.
  8. May 24, 2019 at 12:45 PM
    gr8tacsprt10
    Vince
    Dumped Seafoam last Tuesday
    Changed spark plugs/oil&filter
    Found a loose PCV hose on the driver side, so I bought clamps at autozone
    ....it’s somewhat smoother and doesn’t get the low idle vibration feel
  9. May 24, 2019 at 1:28 PM
    hyper15125
    NJ (609)
    Vacuum leak could definitely have been it.
  10. May 24, 2019 at 8:34 PM
    gr8tacsprt10
    Vince
    Huh.. I did a batt reset. Now it’s back, maybe because it hasn’t cycled readiness earlier.. after driving all day. Now it’s still gives me that low idle issue. I wonder if I have a clogged fuel filter/bad injector (but there’s no codes)/fuel pump giving out...or something else
  11. May 25, 2019 at 6:42 AM
    DayTripper85
    DayTripper85 Well-Known Member
    2005 Tacoma DCSB Off Road
    How bout pulling the injectors and cleaning them. When I replaced my head gasket I noticed two of the injectors we're nasty and partially clogged. My truck purs like a new one now. It's not a difficult job, and while you are at it you can check the hoses, pcv valve, and maf sensor.
    There's a way to send an electrical charge to the injectors to open them so you can spray acetone through them to clean them. There are a few other methods too I just haven't used them.
  12. May 25, 2019 at 7:09 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I've noticed when my truck is in Park and sitting idling (like waiting in a drive thru), there is a very uncomfortable undulation around 750 RPM.
    If I play around with the RPM, the undulation goes away.
