engine vibration after head replacement
Discussion in 'Technical Chat' started by fishtaco72, Mar 27, 2011.
  1. Mar 27, 2011 at 5:19 PM
    fishtaco72
    fishtaco72 [OP] New Member
    okc
    95 taco 2.7 4wd
    I have a 1995 taco 4x4 with the 3rz fe engine. I recently replaced a cracked head and did a timing chain cover gasket while I was there. While removing the crank pulley I turned the engine counter clockwise which caused me to break and replace the left timing chain slipper. I got it all back together and it runs great, except for a constant engine vibration. The vibration happens when parked or driving and the frequency seems to increase with rpm; however, when driving it is only noticable when accelerating and idiling. I also got three new DTC's, misfire #1 cyl, misfire #2 cyl and crankshaft position sensor circut A performance. I took the valve cover off and verified the valve timing to be correct, I also reinstalled the distributor, and checked the compression, which ranged from 170-180 psi cold. Anybody got any ideas?-Thanks
  2. Mar 27, 2011 at 5:23 PM
    98tacoma27
    Ben
    Not Beech Creek
    That crankshaft position sensor can cause all of what your describing.
  3. Mar 28, 2011 at 10:32 AM
    fishtaco72
    okc
    95 taco 2.7 4wd
    Thanks 98
