Engine vibration after Recall has been Fixed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ToyoTacoma08, Jan 10, 2013.
  1. Jan 10, 2013 at 10:57 PM
    ToyoTacoma08
    ToyoTacoma08 [OP] Well-Known Member
    06 Tacoma Regular Cab
    Ok so today I took my 06 4 cylinder Tacoma in for the spiral cable recall. As I was there the service rep said there was another recall that has to do with the Ecu so whenever you press on the brakes it overrides everything else. Well anyways i picked up my Tacoma and drove it home. As I was at a couple of stop lights i felt vibrations through my cabin. I look at my Rpms at standing still idle and it's at 600 Rpms. I never felt the vibrations before I took it in. Can someone out there please tell me where your 4 cylinder 2nd gen idles at?
    Yes the engine was at normal temp and there was no heat or ac running. But when I did have the heat blow it was jump up to 8-900 Rpms and go back down to 600 I could notice the vibrations.
  2. Jan 10, 2013 at 11:14 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    mine typically idles between 800-700
  3. Jan 11, 2013 at 1:45 PM
    ToyoTacoma08
    Thanks for the reply
  4. Jan 11, 2013 at 4:03 PM
    Barbaro
    Barbaro Active Member
    06 PreRunner DCSB Indigo
    I had the Spiral Cable recall done a couple of days ago too. No vibes or ECU recall done, but I did have the passenger door window switch recall done and now no having to roll down the passengers window for them.
