Engine Vibration/Rumble After Mount Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by get5007, Oct 7, 2015.
  1. Oct 7, 2015 at 11:52 AM
    get5007
    get5007 [OP] New Member
    2002 Toyota Tacoma
    2.4L
    4 Cylinder
    2WD
    I purchased this truck roughly 2 years ago with 79,000 miles on it, single owner in Alabama (flat part of the state). It now has 137,000 miles on it.
    Over the past several months there has been an increasing vibration in the engine. The roads I drive everyday are rough. The highways in Louisiana are shit and I work at a mine and have to drive roughly 4 miles of gravel/mud road everyday. I average 100 miles every day for my commute. I have recently replaced the fuel pump (shat the bed on me), rear shocks, front shocks (they were originals), and spark plugs. The vibrations continued to increase until the point were I decided to change the motor mounts and transmission mount.
    The vibrations/rumble before the mount change were very noticeable in the steering wheel, front dash, hood. They were only noticeable when I am stopped (Park, Neutral, Drive). This was whether the engine was cold or warm.
    After the mount change the car does not vibrate when I just start the truck up for the drive. As soon as the engine begins to warm up and I am stopped the engine will start to rumble/vibrate. I am now feeling the majority of the vibrations in the center console, seat underneath me, somewhat in the door. When I turn the A/C on the vibrations/rumble seems to smooth out. Again I can only feel the rumble/vibrations when I am stopped (Park, Neutral, Drive). My idle seems to fluctuate a little when idling. Every now and then it will jump up to 1100 and then back down to the 700-800 rpm idle. Also, I am hearing considerably more valve tapping than usual. It has been on my list to check the valve clearances but I have not had the time.
    Any suggestions on where to start to chase the cause of this vibration down.
    GQ7227 likes this.
  2. Oct 7, 2015 at 12:03 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Center driveshaft bearing? Its located under where the center console is. Not saying its definitely the case, but if so there is a DIY here for it. Body mounts also might be the case.
  3. Oct 7, 2015 at 12:13 PM
    get5007
    Would a bad carrier bearing cause engine rumble and vibration at idle (foot on break) in (Park, Neutral, and Drive)? I would think that a bad carrier bearing would cause vibration upon acceleration. You can clearly see the engine rumbling heavily when stopped (only after warm).
  4. Oct 7, 2015 at 1:28 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    No, if you feel this vibe at stand still (park/neutral) Your issues are else where, did you watch pulley/belt operation while running ? You said something about a mount ? was it motor mount or trans mount ? Check them all again.. Get some audio/video if you can, helps a lot...
  5. Oct 7, 2015 at 1:30 PM
    get5007
    All three mounts were replaced (right motor, left motor, transmission mount). I will try and take some video today after work. The pulleys/belts all seem to be fine.
    GQ7227 likes this.
  6. Oct 7, 2015 at 1:32 PM
    Caligula
    Los Angeles, CA
    Depends, is more audible or can you feel it below the console? It can certainly cause audible vibration when stopped or when creeping forward. If its also easily felt in the body, then it may be something else.
  7. Oct 7, 2015 at 1:39 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Kinda wondering how a carrier bearing is going to make noise or vibrate at a stand still, not turning...
    GQ7227 likes this.
  8. Oct 7, 2015 at 2:20 PM
    Caligula
    Los Angeles, CA
    Not the bearing itself, the mounting on the body possibly being loose. Ive seen it on other cars, not speaking form experience with a Tacoma.
  9. Oct 24, 2015 at 4:34 PM
    cakeboy06
    cakeboy06 Member
    1996 Taco 2wd Ex-cab Automatic 2.4L 200,000+
    I have the same problem with the same engine. Starting to get really annoying! Serious vibration at idle in gear while not moving. Seems to be caused by low rpm's. With the a/c on the engine rpm's are raised to compensate=no vibration. Hasn't been an issue this summer because the a/c is always on. When first started the rpm's are raised also=no vibration. I have been thinking about doing seafoam to see if that will help. It isn't the carrier, and it isn't the mounts for sure. I run a used car lot/repair shop so the last thing to get worked on is my daily driver truck unless it causes it to not run. lol. Would be nice to know what to go after to save time/laziness.
    GQ7227 likes this.
  10. Oct 24, 2015 at 5:03 PM
    gearcruncher
    Canadain bumper technician
    Have you scanned for codes ? Its a computer controlled engine .
    Sounds engine related to me . If the vibe is fealt when you are at a standstill in park with the engine running , you have eliminated the drivetrain as being the problem . Throttle body cleaning ? Mass air flow cleaning ? Remove the serpentine belt and start the engine for a short test
  11. Oct 27, 2015 at 6:52 PM
    cakeboy06
    cakeboy06 Member
    Working with a Snap-on Verus wireless to check my codes. No codes, but I know the truck shouldn't idle at 550-600 rpms once it warms up. I've been working on transmissions since I was young (3rd generation transmission mechanic owning our own businesses), and that picture of your tranny pan magnets is funny. Was that the planetary gears that exploded? I love my taco, but I keep an old V8 explorer around for towing my boat and other stuff. Sorry I made fun of your pain.
    GQ7227 likes this.
  12. Oct 29, 2015 at 5:51 PM
    cakeboy06
    cakeboy06 Member
    Seafoamed my turd today. Made a HUGE difference! Only drove it home from work today. I'll see how it does tomorrow.
  13. Feb 24, 2016 at 2:49 PM
    cakeboy06
    cakeboy06 Member
    Found the problem. Engine idles around 600 RPM, but I guess the only way to fix it is by replacing the ECM.
    Subject: Rough Idle correction for 1995-97 Tacoma with 2RZ-FE or 3RZ-FE engine
    Source Toyota technical service bulletin EG006-00 (August 2000)
    The operating logic of the replacement ECM has been revised to improve engine idle
    smoothness. This is accomplished by raising the engine idle speed with the A/C off. The
    change also narrows the engine speed transition between A/C off and on conditions.
  14. Jul 3, 2019 at 5:05 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    yikes, talk to me about this
    help me to diagnose gremlin rattle rumble vibration
    its been going on a few months now
  15. Jul 3, 2019 at 5:25 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    HFS how come nobody has pointed me to this thread yet ?!?!?
    how the heck does this work with MT
    most of this info is with AT
    :help:
    @1997tacomav6 ... have you run into this issue within this very old thread?
    perhaps anybody else?
    there has been no topic thread on this for 3years now
  16. Jul 3, 2019 at 5:29 PM
    1997tacomav6
    Denver
    Nope, only vibration issues for me was a bad Cardan joint
    GQ7227[QUOTED] likes this.
  17. Jul 3, 2019 at 5:32 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    and your mileage!
    rubber engine mounts, these are a function of years some would say
  18. Jul 3, 2019 at 5:33 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    you never hardly run your truck at 2.1k rpms in all gears do you?
    i mean when you shift you are never going back to there and speeding up for next gear
    i do and this is where i get my rattling most the time lately
  19. Jul 3, 2019 at 6:38 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    @1997tacomav6 ... have you had any issues with this ECM?
  20. Jul 3, 2019 at 7:17 PM
    1997tacomav6
    Denver
    Still on original motor mounts
