Engine Vibrations at 700-850 rpm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NumNutz, Sep 18, 2015.
  1. Sep 18, 2015 at 4:36 AM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Getting engine vibrations from 700-850 rpm (just slightly above idle). Doesn't matter what gear I'm in which makes me think it's not driveline related. After doing some searching I'm thinking potentially bad motor mount or maybe an issue with the A/C compressor. I'm really no guru when it comes to diagnosing issues, so I'd love to hear your input.
    Vibrations are moderate and at idle are non-existent. Once you get above about 850 or so they go away as well.
    I get the vibration in all gears, including neutral (I'm an automatic), but only when the rpm is slightly above idle (700-850 rpm). I don't believe it to be drivetrain related.
  2. Sep 18, 2015 at 7:10 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    do they happen in neutral/ not moving / ac on or ac off.
  3. Sep 18, 2015 at 12:11 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Completely rpm based. A/C on or off. Pretty much rules out the compressor. Happen in any gear.
  4. Sep 18, 2015 at 2:54 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Do you get a vibration in neutral Not in gear when you rev the engine?
  5. Sep 18, 2015 at 3:03 PM
    NumNutz
    Virginia Beach, VA
    Lots.
  6. Sep 18, 2015 at 5:04 PM
    nd4spdbh
    SoCal
    so it will do it stopped in gear or neutral?
    Hmm..
  7. Sep 18, 2015 at 5:43 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Correct. If I hold the brake (so the truck isn't moving) while in drive and just give a little bit of throttle to get the truck in the correct RPM range, I get the vibrations. Same thing in neutral.
  8. Sep 18, 2015 at 5:47 PM
    NumNutz
    Virginia Beach, VA
    Lots.
  9. Sep 18, 2015 at 8:38 PM
    nd4spdbh
    SoCal
    haha.... that exact thing happened to me the other night.... *head bang against wall*
    Id check motor mounts. Maybe get a wooden dowel so you can use it as a cheap stethoscope on various spinning parts of the motor.
    You got video?
  10. Sep 18, 2015 at 8:58 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    A slight vibration between 750 - 850 RPM isn't a high spot on the priority list IMO. Do you even drive at 850 or less RPM.
    Def not drive train related and I seriously doubt it is a motor mount. What year Tacoma is it? Engine?
  11. Sep 19, 2015 at 6:31 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    07 with a 4.0. It's confusing to me that it would be in such a specific RPM band
  12. Sep 19, 2015 at 6:51 AM
    PHTaco
    PHTaco Well-Known Member
    Brooks
    TX Panhandle
    '13 Trail Limo
    Kings-Dakars-Dirty Fives RCI Skids Demello front bumper BAMF Sliders HC Rear bumper Snug top 4.56 Nitros Engo 9000# Winch w/ syn rope ARB comp & rear locker Home built roof racks Expo trailer w/ RTT
    My '13 did that from new until I did the 30k mile spark plug change. I went with Denso in all six rather than the NGK/Denso mix they come with from the factory. You have probably already done this being an '07, but thought it was worth mentioning
  13. Sep 19, 2015 at 7:04 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    It's probably been roughly 30k since I've done my spark plugs...
    Similar rpm range?
  14. Sep 19, 2015 at 7:08 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    It probably wouldn't be a bad idea to do ur plugs. I'd also do a throttle body and MAF cleaning. Just to rule those things out...
  15. Sep 19, 2015 at 6:58 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    I'll do that and report back. Thanks guys.
  16. Oct 14, 2015 at 6:03 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    After a spark plug change, still getting the vibrations, but I would say they're now in the 750-850rpm range now. Still have to do a MAF and throttle body cleaning. Do you guys use specific MAF and throttle body cleaner when doing that?
