Engine vibrations post EFI swap (@ idle only)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Morden, Feb 21, 2023.
  1. Feb 21, 2023 at 8:57 AM
    Morden
    Morden [OP] Well-Known Member
    Cali Central Valley
    2002 Tacoma TRD PreRunner
    Bear with me on this one. :p
    I'm getting a strange slight vibration at idle (which is fine BTW). Acceleration from a stop or getting on a freeway on-ramp is fine, as is steady cruising. I've so far done the following:
    Replaced engine and transmission mounts.
    Checked all vacuum hose connections.
    Checked spark plug wires and caps/boots (plugs were changed at the same time as the injectors, early last month).
    Cleaned MAF sensor & throttle body.
    Ensured that I didn't switch the coolant and vacuum lines to the TB.
    Did an ATF drain and fill (fluid was fine, not brown or burnt-smelling).
    Replaced the rubber donuts that the exhaust system hangs from except for the forward ones, because they're a bitch to reach.
    The engine currently stands at 205k miles and while I know that I should check the valve clearances (my next job as soon as weather and work conditions allow), I'm aware that the valve train gets quieter as clearances tighten up. I'm still hearing some clatter beneath those valve covers.
    I haven't crawled beneath the truck yet to see if anything could be loose, such as an exhaust/cat shield.
    The truck doesn't shake anything like it did when I had the misfire a couple of months back. I'm thinking that it could possibly be the fuel injectors themselves...I've been present when I had a couple of sets of motorcycle injectors cleaned at a local performance shop, and when they were firing in the test tank I was amazed at just how noisy they were. Anyway, this noise it just enough to trigger my OCD. o_O Anything I might have missed? Alternator bearings? PS pump?
  2. Feb 21, 2023 at 9:23 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Have you checked your idler pulley? Normally it makes more noise than vibrations, but still worth checking. Do you have an automotive stethoscope? If not, I'd recommend picking one up, and just poking around throughout the engine compartment with it to see if you can pinpoint a noise that seems to be related to the vibration you're sensing. I also had a very minor vibration at idle that new coil packs solved. My understanding is that coil packs can wear out and still function adequately, but cause slight vibrations at idle and decreased fuel economy. Just a couple thoughts, hope it helps.
  3. Feb 21, 2023 at 10:47 AM
    Morden
    Cali Central Valley
    Good call on the coil packs, since they are original (2002). Getting a stethoscope this week.
    I think the idler pulley was replaced when I had the radiator & water pump done in 2021.
  4. Feb 21, 2023 at 9:39 PM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    New mounts are OEM?
  5. Feb 23, 2023 at 7:31 AM
    Morden
    Cali Central Valley
    Yes. I try and use oem parts in critical areas as much as possible.
  6. Jul 26, 2023 at 2:21 PM
    Red_03Taco
    Jerad
    @Morden - OP did you ever resolve your vibration issue?
  7. Jul 28, 2023 at 8:14 PM
    Morden
    Cali Central Valley
    Still vibing, hasn't gotten worse. :p I figure it's either the AC compressor or the harmonic balancer.
  8. Jul 28, 2023 at 8:26 PM
    Red_03Taco
    Jerad
    Ok, I'm hunting down what sounds like the exact same thing on my truck. I've done everything you mentioned too. Considering trying new injectors soon. My OCD won't let me stop searching even though it's very faint. Thought I'd check if you'd found the secret sauce lol
