Engine warm-up in the morning. Is it necessary?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zer0, Dec 17, 2013.
  1. Dec 17, 2013 at 9:22 PM
    Zer0
    Zer0 [OP] Well-Known Member
    SGV, California
    99 PreRunner
    Hello all. Just wondering if anyone warms up their engines in the morning. I usually warm it up until the rpms drop below 1k - usually takes 10 minutes or so. I was told by others though that obd2 cars dont need to be warmed up because the o2 sensor gives everything the right temperature anytime you start the car, cold or not. thanks.
  2. Dec 17, 2013 at 9:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I usually warm mine up, but not for ten minutes. Maybe 2 or 3.
    Mostly want to get all the fluids circulating before revving higher than idle. The scangauge shows the transmission wont shift to 3rd until the fluid temp is above ~85*F but sitting at idle takes a long time to get it there on winter days so again, no point in letting it idle for more than a couple of minutes.
  3. Dec 17, 2013 at 11:56 PM
    Zer0
    SGV, California
    99 PreRunner
    LOL. thanks for the replies. I guess 10 minutes is a little long. I always thought I had to warm it up until the rpm went under 1k...i guess thats a honda thing. anyways, thanks for the replies. ill cut down my warm up to a few minutes.
  4. Dec 17, 2013 at 11:58 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    i wait maybe 30 seconds and go for it..haha
  5. Dec 18, 2013 at 12:05 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    I let mine warm up until i see them temp gauge get up to being within bracket
    My manual usually doesn't start shifting real smoothly until the temp gauge makes it up to 1/4 - 1/2 (I've got MT-90 in there and it's properly filled)
    I don't like to just turn the key and go, if for no reason, other than that
  6. Dec 18, 2013 at 12:06 AM
    Zer0
    SGV, California
    99 PreRunner
    thanks for the replies!
  7. Dec 18, 2013 at 12:30 AM
    XxRonZombiexX
    XxRonZombiexX Active Member
    Ron
    Ok
    10 TRD Sport 4x4 DC, 98 Ext. Cab 4X4
    I let mine stay running I till it's warm in it, I ain't trying to drive when it's freezing, haha
  8. Dec 18, 2013 at 12:34 AM
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    Crank n go.....naw if its real cold like 35 lowest it gets normally around here. But thats at night during the day itll be 50+. im drunk and rambling
  9. Dec 18, 2013 at 5:17 AM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    I start it and go. Then again, I'm in Phoenix. Summertime oil temps are over 100f on a cold start. :p
  10. Dec 18, 2013 at 5:45 AM
    Madjik_Man
    Colorado Front Range
    I usually wait until the high idle kicks down a bit, then I go. Maybe 2 minutes tops?
  11. Dec 18, 2013 at 6:03 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    I give it around 10 minutes or so - wait for the heat to actually warm the interior before I go sit in it.
    Also I hate the feeling like my clutch is being worked with syrup.
  12. Dec 18, 2013 at 6:48 AM
    Tmiller3063
    Tmiller3063 Active Member
    04 Prerunner Limited
    I usually give it 1 to 3 minutes depending on how cold it is. If it is real cold I will go outside and start it and turn the heat on and then go back inside for about 5 minutes.
  13. Dec 18, 2013 at 6:53 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    The faster I get going the faster the truck warms up.
  14. Dec 18, 2013 at 6:53 AM
    bozotaco
    bozotaco Well-Known Member
    Montana
    04 Tacoma
    I've been in Duluth, Minnesota for the last month and its cold every day. Like -4 for the last week or so. I usually give it five minutes, but I have also waited thirty seconds or so and driven and have not had any issues pushing in the clutch. Sometimes however shifting into second is tough if I have just started the truck with little time to warm up. Anyways the guys on cartalk say thirty seconds is sufficient.
  15. Dec 18, 2013 at 7:00 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    I only warm it up if my daughter is coming with me. Otherwise I crank and go. I do take it kinda easy on her at first.
  16. Dec 18, 2013 at 7:05 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I read somewhere that you should at least wait 30 seconds before shifting into drive after starting no matter what the temperature is outside. It had something to do with it takes that amount of time for everything to start circulating.
  17. Dec 18, 2013 at 7:16 AM
    BamaToy1997
    Bill
    Navarre, FL
    In general, even the OBDII vehicles should be given at LEAST 30 seconds of idle before shifting it into gear. Is it NECESSARY? No. Is it a good idea? Yes. When the fluids are cold, they are thicker obviously. This means that they resist flow a bit. This resistance to flow means that when you increase your RPMs, the fluids MAY (I didn't say will, I said may) resist flow enough that any RPM over 1500 could result in improper lubrication for a very small amount of time (seconds). Now sure, this does not seem like a lot, but in my book anything that I can do to make my engine or transmission last longer, is a good thing. Not to mention the ALREADY thick gear oil in the diff needs to splash around some. Even in the summer I give it a little bit before I move.
    Basically at a minimum I will sit in the seat, start the truck, then put on my seatbelt and get settled in the seat. By then it has run enough to get the fluids going good. Just my $.02 worth.
  18. Dec 18, 2013 at 7:23 AM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    When I drove Porsche cars (that feels like a lifetime ago) the factory sent out a bulletin, recommending that even with synthetic fluid, to keep rpm's below 2K until the coolant and the oil were warm. That takes about 10-15 minutes of easy driving, and that is exactly what I do.
    Even when I don't go to the office, on cold morning, I avoid high speed roads, until my vehicles engines are fully warmed.
  19. Dec 18, 2013 at 7:37 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    This^
    This isn't true... O2 sensors don't start operating until they reach about 600 degrees. Until they reach that temp ur engine is operating in open loop mode
  20. Dec 18, 2013 at 7:42 AM
    BamaToy1997
    Bill
    Navarre, FL
    Yes, but most vehicles built since the late 90s have heater elements built in to the O2 sensor. They usually reach optimum temp within 30 seconds. (Thanks for the support on my other post!)
