Engine warm-up in the morning. Is it necessary?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zer0, Dec 17, 2013.
  1. Dec 18, 2013 at 11:59 AM
    #41
    Roundarc
    Roundarc Born again Tacoma Owner
    Allan
    Virginia
    2025 TRD Sport Premium
    ^^^This
    My wife's Subaru has a blue "Coolant Temperature Low Indicator" light that comes on after start up. This light usually goes off after about 2 minutes once the engine has warmed up enough. You can drive while it's lit, it's not recommended that you put your foot in it until the light goes off.
  2. Dec 18, 2013 at 12:58 PM
    #42
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You would feel like everyone in the Military. :mad:
  3. Dec 18, 2013 at 2:06 PM
    #43
    A3umph
    A3umph Well-Known Member
    outside of KCMO
    '12 Tacoma Access Cab TRD OR
    LMFO ................How true..........
  4. Dec 18, 2013 at 4:29 PM
    #44
    polack
    polack Well-Known Member
    I live in wisconsin. Cold as fuck here all the time. i always start mine and let it idle for 15 to 20 minutes. I like it that it is warmed up in the cab for me and i drive with a very heavy foot. so i want to make sure my truck is ready to go. Before anyone posts, I know this is crazy but i like warm air. hate the winter.
  5. Dec 18, 2013 at 4:35 PM
    #45
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Start it. Hail Mary it. Go.
  6. Dec 18, 2013 at 5:06 PM
    #46
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    For me it depends on the temp. outside. The colder it is out, the longer I let it idle. Most of the year it's only 30-60 seconds I prefer for it to warm up as I'm driving down the road.
    I think it's not a good idea to start it up and park it before reaching operating temperature. You want to make sure that the engine oil is hot enough to burn off any moisture.
    RJM
  7. Dec 18, 2013 at 8:35 PM
    #47
    Zer0
    Zer0 [OP] Well-Known Member
    SGV, California
    99 PreRunner
    Awesome the responses this thread is getting! Thanks again for all your replies.
  8. Dec 18, 2013 at 9:18 PM
    #48
    BamaToy1997
    Bill
    Navarre, FL
    The O2 sensor is usually warmed up within 30 seconds. Closed loop at that point. Until that it runs in open loop, where it uses ECT, IAT, TPS, MAF and MAP sensors for fuel management. Of course 30 seconds is no time at all. Engines these days go into closed look operation pretty fast. Still I don't recommend a "start and go" policy when it is below freezing.
    Neither is perfect, but the first option has the highest risk of long term damage if done regularly.
  9. Dec 18, 2013 at 9:27 PM
    #49
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Engine warms up faster being driven than sitting idling.
    Chris4x4 did a comparison, so did I. Don't recall the numbers but it was a HUGE difference... on the order of like 5 minutes vs 20 minutes before I was able to feel heat out the vents (and 10 minutes of normal driving to get the temp gauge into the normal range).
    +1 to Bama. Give it 30 seconds and drive casually until it's up to temp.
    Excessive cold idling is not good for the cats and can cause oil contamination from the rich mixture.
  10. Dec 18, 2013 at 9:31 PM
    #50
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    I warm up for about 3 minutes, then drive slowly out of the neighborhood. By that time warm air is starting to blow and the manual shifting starts to smooth out. I never jump in and take off.
  11. Dec 18, 2013 at 9:36 PM
    #51
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I just drive easy on it, minimal accessories, until the engine warms up when its really cold (40s and under for us fl folks).
  12. Dec 18, 2013 at 11:38 PM
    #52
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    I start it up and then wait for the rpm's to drop below the 1250 mark then drive her easy and try to keep the rpm's low until the temp gauge shows the truck's up to operating temp.
    Depending on how cold it is, this might be 30 seconds or 2-3 minutes. I usually plug the truck in when it gets below 10 or 15 degrees, and that sure helps a lot!
  13. Dec 19, 2013 at 12:02 AM
    #53
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    both of these ^^
    i'm not contesting the people who say 30 seconds and go is fine; but, i wonder if they have a manual or automatic and what type of temperatures we're talking about here
    the OP didn't specify "cold mornings"... he just said "morning"; I just kind of ran with the assumption we're talking about bitter cold
    and in that case: my manual will not let me smoothly shift and the clutch won't smoothly disengage, short of me letting it out WAY slower than usual, until my temp gauge is between 1/4 and 1/2; and that takes quite a bit longer than 30 seconds (i'm aware the temp gauge isn't affliated with trans and clutch temps)
    while i'm not prepared to say that means damage is happening, it's certainly not operating anywhere near normal 30 seconds after i start it on a -7 degree morning... and besides, it's still freaking -4 degrees, at most, in the cab 30 seconds after i start it... who wants to sit in that. haha
    if it's cold out, i try to wait until the temp gauge at least budges from it's buried state
  14. Dec 19, 2013 at 1:57 AM
    #54
    Tiberius
    Tiberius Well-Known Member
    Aurora, CO
    Nautical Blue v6 SR5 4x4 Access Cab
    Ever heard a strange groan? That's your engine getting fluids in sub-zero and it takes seconds before it goes away. Ever had coolant freeze? How do you get your engine up to temp and get fluids up to temp in sub-zero? Drive your truck! If its idle is at 1500 or whatever why not just drive it and it will be around there most of the time. I've always waited seconds (or until I scrape the snow off) and then driven gently (its probably snowy anyway, or icy), and never had any related issues on any of my trucks.
  15. Dec 19, 2013 at 5:34 AM
    #55
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    It's been a long time since I sold a vehicle that had less that 200K on it in Maine it is not unusual for the temps to drop into the -20's. I drove a VW diesel 230K before I sold it with 327K. It would not warm up unless it was driven and if it was warm it would cool off if it sat idling. Granted a diesel is far more efficient that a gas engine but the facts still remains it takes far longer for an idling engine to warm up than it does driving. This means better mileage less oil dilution etc. By the time you have a seat belt on adjusted everything you’re good to go on matter how cold it is. An engine feels no pain not like a runner drug out of bed. So if you let it idle will the engine last 10K longer? Or maybe it makes no difference or maybe it will last 10K less will you ever find out?
  16. Dec 19, 2013 at 7:00 AM
    #56
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    WOW. I'm REALLY surprised nobody has brought up the point that a cold engine is out of spec.
    You guys are all aware that metal expands with heat...right? You're all aware that, when cold, you cylinders and pistons have crazy amounts of gap...right? If you run an engine cold, it will cause piston slap. Maybe you don't notice it because you're busy driving at 2.5k RPM (too fast to hear it), but you ARE causing damage.
    When cold, your cylinder gets bigger while your piston gets smaller. That's not even the half of it with piston rings. Piston rings barely work worth a damn when cold. Ever heard of ring gap???? The gap you leave between the two ends of the ring to allow expansion when heated up?
    Anyway...your truck, not mine. Your engine, not mine. Your $3000 rebuild, not mine.
  17. Dec 19, 2013 at 7:58 AM
    #57
    teehext
    teehext Well-Known Member
    Tyler
    CA
    2001 PreRunner SR5
    ^ A good point, but how long do you suggest warming up your truck to minimize that damage?
  18. Dec 19, 2013 at 7:59 AM
    #58
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    i warm up until the temp gauge hits the first tick mark
  19. Dec 19, 2013 at 8:08 AM
    #59
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    In the old days, warming up the engine was the norm. Due to improvements in engine technology long warmups are no longer necessary.
    In the summer 20-30 seconds just to get the oil circulating and oil pressure up.
    In the winter, maybe a minute or so.... and then run it normally with no hard acceleration for the first few miles.
  20. Dec 19, 2013 at 10:28 AM
    #60
    fast5speed
    Washington D.C.
    I'm not sure. I'm not an expert in metallic properties or clearances. But I do know basic chemistry attributes. Metal expands when warm and contracts when cold. I also know that a thinner oil will act like a much thicker oil when cold.
    Some motors will warm up faster than others. My little 1.5l Honda motor only takes a couple minutes. With a diesel (even modern ones) it's a very unpleasant warming up process. My friend's father grew up in northern Michigan. He told me that in the 70s and 80s, people never turned their diesels off. Just let them idle all night long. Because those fuckers wouldn't start up again in the morning. Or you would kill you battery trying.
    Pretty common mis-conception. Yes, modern technology is lightyears better at managing how to operate the motor, but metallic properties of expansion and contraction haven't really changed.
    here's a story you guys might enjoy. I used to be a Nissan guy. I was a member of a Nissan truck forum, much like this one. I guess the Japanese like to sell lots of their trucks in Canada? So there were a lot of Canadian members on the forum. Some of them from so far north, that the high temp of the day would often be -~50F or colder in the winters.
    So you all know you're supposed to regularly change the fluid in your diffs. One guy was experiencing issues with his rear diff when it was cold (lol understatement). He went to drain the old diff fluid. Nothing came out. He was worried about possible damage to the diff, so he took the housing cover off. It was so cold, that his differential fluid was one solid block.
    Some other Canadian members in much "warmer" climates would report it taking hours upon hours for their diff fluid to drain.
    Has it ever been so cold that your blinkers don't work for a couple minutes? Ever been so cold that your clutch just slips like ice?
    Just a little food for thought when you start a cold motor in the morning. My cars take enough abuse while warm, I don't consider it fair to beat them while cold.
