Engine will not start..hear a clicking noise. NEED HELP!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by trdracing5, Apr 11, 2012.
  1. Apr 11, 2012 at 12:22 PM
    trdracing5
    trdracing5 [OP] Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    I am trying to figure out the problem with my sons 2000 4Runner with the 3.4 V6 and an auto trans.
    It will not start.
    You can turn the key and all of the dash lights and stereo come on but it does not turn over all you hear is a "click".
    I put a new starter in this morning and that did not help.
    I put a new starter relay in this afternoon and that did not help.
    The battery is fine. I tried the battery out of my tacoma and that did not help.
    The auto parts guy said it could be the ignition switch?
    Anyone got any ideas.
  2. Apr 11, 2012 at 12:25 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    All signs point to starter, but you put in a new one...uuhhh
  3. Apr 11, 2012 at 12:47 PM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    Id take a look at the starter you installed, make sure all the connections are good.
  4. Apr 11, 2012 at 2:56 PM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    Have your battery tested, a bad battery does not have enough amperage to turn the starter over, so you will just get a clicking noise, but still have enough power to turn the lights on...
  5. Apr 11, 2012 at 3:04 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Neutral safety switch? Mine went bad after a dip in some water and all it did was click, try to start "N" if you have an auto trans.
  6. Apr 11, 2012 at 4:14 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    2017 Tacoma Dbl cab long bed.
    Hood Strusts, remote Start, truck came with Leveling kit and wheels.
    Sounds like the starter. But check your battery first.
  7. Apr 11, 2012 at 4:17 PM
    Murkules
    Murkules Well-Known Member
    Dane
    Hawaii
    2016 Tacoma TRD Offroad DCSB Super White
    Is the shifter in park?
  8. Apr 11, 2012 at 10:34 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    I'd check the wiring between the battery positive and the starter. The clicking you hear is probably the starter solenoid, which means everything else in the circuit (including the ign switch) is working fine. Unless your new starter is defective, it's probably the main power wire to the starter.
  9. Apr 11, 2012 at 10:38 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Replace the battery terminals, probably a bad ground like Whippersnapper said.
  10. Apr 12, 2012 at 7:41 AM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    a buncha fuckin toyotas
    Starter relay?
    Solenoid?
    Sub'd for outcome. Good luck.
  11. Apr 12, 2012 at 7:44 AM
    Mondwa
    Mondwa Well-Known Member
    Michael
    Phoenix, AZ
    08 V6 Tacoma
    remote start, Allpro bumper, Slimchubby HID, MetalMiller custom Emblem
    do u have access to a multi meter? stop buying parts on a whim. get u a way to trace the problem so you only have to buy one part. Sounds like a ground or a low amp in your bat
