Engine Won't Start... HELP!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chad, Jan 3, 2013.
  1. Jan 3, 2013 at 8:56 PM
    #41
    jandrews
    '09 FourDubDee TRD OR
    Pretty much. That and expensive lab tests and radiological imaging.
  2. Jan 3, 2013 at 9:01 PM
    #42
    97lt1ta
    97lt1ta Well-Known Member
    Las Vegas
    07 prerunner
    Sounds like your stock security shit. If it is the battery low would click but already ruled out. starter bad would generally do nothin even if it was a solenoid there still would be a little noise. My money is on security lock out happened all the time to me in my ta
  3. Jan 3, 2013 at 9:08 PM
    #43
    Chad
    Chad [OP] Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    I wish I had that other key :mad:
    Do you know what happens to get you "locked back in"?
  4. Jan 3, 2013 at 9:11 PM
    #44
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  5. Jan 3, 2013 at 9:16 PM
    #45
    97lt1ta
    Las Vegas
    07 prerunner
    I turned it into a drag car so I just ripped everything out. But if you have a volt meter check your starter wire while someone cranks it. Just to rule your starter out could still very well be the starter solenoid or relay. But the security is just another possibility and imop fits. But start with checking the voltage to the starter and the oms on the solenoid. Cause if its the security lock out may have to tow it to a mechanic depending on how mechanically inclined you are
  6. Jan 3, 2013 at 9:21 PM
    #46
    Chad
    Chad
    Cary, NC
    I have a multimeter, but where is this stuff located? I'm not very learned in where this stuff is under the hood.
  7. Jan 3, 2013 at 9:23 PM
    #47
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Starter is on driver side bottom, on bell housing of trans. Solenoid is mounted on starter.
  8. Jan 3, 2013 at 9:40 PM
    #48
    Chad
    Chad
    Cary, NC
    Okay I might try this in the morning before calling to get it towed somewhere.
  9. Jan 3, 2013 at 9:42 PM
    #49
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    make sure there's good "tight" conections on your battery terminals...if its lose just a bit this can your no start issue...might seem like there on there good but double check...
  10. Jan 3, 2013 at 9:44 PM
    #50
    Chad
    Chad
    Cary, NC
    Trust me they're good. I've taken them off and on several times so sometime in that time frame you would think it would have worked had that been the issue.
  11. Jan 3, 2013 at 9:58 PM
    #51
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    This might be useful to you
  12. Jan 3, 2013 at 10:20 PM
    #52
    Chad
    Chad
    Cary, NC
    Whack what, specifically?
  13. Jan 3, 2013 at 10:29 PM
    #53
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    The starter
  14. Jan 3, 2013 at 10:32 PM
    #54
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    He's saying whack the solenoid that's on the starter, although I wouldn't use a hammer directly on it. Put a piece of wood on it and tap that with your hammer.
    The solenoid is just a big relay that is driven by an electromagnet. Sometimes they get stuck. We have a lift truck at work that once or twice a week we stick a hunk of wood onto it and give it a whack to make it start.
    It's free to try it, so why not
  15. Jan 4, 2013 at 9:01 AM
    #55
    Chad
    Chad
    Cary, NC
    Truck is now sitting at the stealership... It had already been towed before I woke up this morning lol. When I last checked it was next in line to be looked at/worked on so I'll let you guys know what they found.
  16. Jan 4, 2013 at 12:31 PM
    #56
    Tommy27
    Tommy27 Well-Known Member
    Tommy
    Boise,ID
    White 09 AC 4x4 2.7 5spd SR5
    Leer shell, Bed mat, Grill Guard
    It could be what happened to my Civic 2 days before someone was supposed to by it. A rodent chewed threw some wires in the engine wire harness. I was panicking, but luckily my neighbor was an electrician and help he fix it. You may want to check that.
  17. Jan 4, 2013 at 12:33 PM
    #57
    Chad
    Chad
    Cary, NC
    There have been some small birds in the garage lately. Saw a few flying around in there yesterday trying to build a nest I guess.
  18. Jan 4, 2013 at 1:38 PM
    #58
    Chad
    Chad
    Cary, NC
    UPDATE:
    Just got back from the dealer. It apparently doesn't seem to be a mechanical problem. They had the whole dash yanked out and some guy was fiddling around with wiring. The guy thinks there was a ground that isn't clicking somewhere.
    Already out about $300 in labor alone.
  19. Jan 4, 2013 at 1:46 PM
    #59
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I would never let those monkeys rip apart my truck to 'fiddle' with wiring..
  20. Jan 4, 2013 at 1:55 PM
    #60
    Chad
    Chad
    Cary, NC
    Not my idea. Dad already had it towed to the dealer by the time I woke up. I did all I could yesterday though and nothing worked so its better than nothing.
