enine code P219A
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pcosentini, Aug 1, 2014.
  1. Aug 1, 2014 at 4:03 PM
    pcosentini
    pcosentini [OP] New Member
    Baltimore
    14 tacoma
    have a 2014 tacoma 2 wd double cab V6 - 640 miles on it - yes that is right 640 miles on it - engine light came on, took it to the dealer they pulled the code then cleared it - they could not come up with anything for that code - 20 miles later light is back on - anybody have any thoughts as to what it could mean ? and why it came back on ? truck had 360 miles on it when nI took ownership of it so as you can imagine how I am feeling about now
    this is a company vehicle outfitted with a ladder rack, auto locking tailgate, bed cover so having a loaner is not really an option! or at least a good one:mad:
  2. Aug 1, 2014 at 7:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don't even see that Trouble Code in the shop manual. Only thing is shows is a P220. I'm interested to know myself too?
  3. Aug 1, 2014 at 8:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Everything that I find points to this:
    P0219A Bank 1 Air / Fuel Imbalance detected.
    The air fuel imbalance monitor is designed to detect differences in the air fuel ratio between cylinders per engine bank. The test fails if the air fuel ratio difference per cylinder is greater than a calculated amount.
    Tell the Service writer what the code means. You should not have to do anything. Warranty. Be firm and polite.
    This is not the plain p0219 for engine over speed, ( Note the A at the end ).
  4. Aug 1, 2014 at 9:10 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    i had this code on a corolla and it had burnt exhaust valves
  5. Aug 2, 2014 at 7:50 AM
    wannabetrd
    wannabetrd Well-Known Member
    Zach
    Michigan
    SR5
    3inch front 2inch rear lift with add a leaf and extended brake lines trd exhaust
    I had that code on a 12 corolla as well burnt cyl 3 exhaust valve was a rental car had e85 in the tank
  6. Aug 2, 2014 at 9:55 AM
    Blacktaco2042
    wisconsin
    lmao had was a rental also but no e85
  7. Aug 3, 2014 at 7:39 PM
    wannabetrd
    Zach
    Michigan
    SR5
    I'm sure it did the tank or two before that lol
  8. Aug 3, 2014 at 8:07 PM
    Blacktaco2042
    wisconsin
    or they beat the piss out of it
