Enkei 16x8” 106.1mm center bore question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by icecapyeti, Jul 3, 2025.
  1. Jul 3, 2025 at 7:37 AM
    icecapyeti
    icecapyeti [OP] Member
    stock suspension 2023 trd OR
    Is it true only 520-680-8400gm (large bore no cap?) which are 108.1mm bore, but not 528-680-8400gm (small cap/bore) which are 106.1mm center bore same as the 3rd gen ('23) Tacoma trd OR axel hub diameter. I guess there's an issue with 528-680-8400gm(106.1mm bore) center bore tapering which may interfere with the tacoma's dust cap causing improper seating on axel hub. If anybody can shine some light on this. Thank you in advance!! I mayhave bought the 528-680-8400gm :facepalm:
  2. Jul 3, 2025 at 9:32 AM
    icecapyeti
    C’mon somebody help me out
  3. Jul 3, 2025 at 3:20 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I read your post earlier today and found I knew nothing about what was being said, by what you have posted. Perhaps including a few pictures or links to the products to get people interested would help. It was just mumble-jumble to me. Also, include your title in the text of your question always helps. Sometimes we are so focused on our own problems we don't think about clear communications.
    OK, what I did get out of it is that some filing maybe necessary.
  4. Jul 4, 2025 at 7:08 AM
    JSAC3
    JSAC3 Member
    Justin
    Georgia
    2019 ACLB - Utility Package
    People have had issues with the smaller bore fitting over the dust cap on 4x4 models. But they would just remove or modify them. I have the large bore, so cant speak specifically to this issue, But I believe others were able to make them fit relatively easily
