Enkei rpt1 16x8 w/ 106.1mm center bore question
Discussion in 'Wheels & Tires' started by icecapyeti, Jul 2, 2025 at 11:02 PM.
  1. Jul 2, 2025 at 11:02 PM
    icecapyeti
    icecapyeti [OP] Member
    Wednesday
    stock suspension 2023 trd OR
    Is it true only 520-680-8400gm (large bore no cap?) which are 108.1mm bore, but not 528-680-8400gm (small cap/bore) which are 106.1mm center bore same as the 3rd gen ('23) Tacoma trd OR axel hub diameter. I guess there's an issue with 528-680-8400gm(106.1mm bore) center bore tapering which may interfere with the tacoma's dust cap causing improper seating on axel hub. If anybody can shine some light on this. Thank you in advance!! I may have bought the 106.1mm center bore 528-680-8400 :facepalm:
