Enough Already! Your Truck's T, HP and RPM Explained
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hiPSI, Oct 24, 2018.
  1. Mar 4, 2019 at 7:54 AM
    #381
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    I'm not calling YOU out either, and I love my 1.05 93 tune, but isn't it unreasonable to flash a new tune and then immediately put the truck on a dyno? Aren't all the learned values correct for the previous tune, not allowing the new tune to take full advantage of changes in AFR, Timing, etc.? If Mat had put the requisite 300 miles on the TSB 04B04 tune before testing, the gains would likely have been even greater, no? Or, even if you cleared all learned values before running the TSB tune (which it probably does on its own?), timing and fueling would likely be very conservative until the ECU 'learned' what it could get away with.
    Am I missing something obvious?
    Frank
    MOC221_[QUOTED] likes this.
  2. Mar 4, 2019 at 8:24 AM
    #382
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Nope, and your questions are valid. We who are tuned all know that a file settles in over a few hundred miles. If we want to split hairs, it would've been more of a "fair" test to reset learned values (techstream) on the factory 04B03 calibration, let it idle for 5 minutes, then do your dyno pulls when up to temp. Then flash to 04B04 and follow the same procedure. Mat could've done that, although he didn't say so. These were both Toyota files BTW, I didn't say anything about 1.05.
  3. Mar 4, 2019 at 8:30 AM
    #383
    MOC221_
    Frank
    There is an updated file for your truck from Toyota (Cal ID 04B13). My truck is an early production 3rd gen M/T, manufactured 09/15. 04B13 is miles ahead of the original factory calibration she came with IMO (04B10).
    shakerhood likes this.
  4. Mar 4, 2019 at 2:53 PM
    #384
    909digger
    909digger Member
    Dan
    19 TRD Pro
    I've farted in the seat.
    The issue is drag (wind resistance). This 3 5 motor is great in a Camry. But the drag on the truck is twice that of the car. While driving 70 the motor is turning about 2000r's. The motor doesn't make enough torque to overcome the drag at that rpm range. If they tightened up 5th and 6th gear getting the rpm into the 2500 range then maybe it wouldn't shift to 4th anytime you start up an overpass. And it would probably be more efficient 40%throttle at 2000rpm uses more gas than 20% at 2500rpm.
  5. Mar 4, 2019 at 2:59 PM
    #385
    IRISHFAN
    IRISHFAN Well-Known Member
    Jeff
    SE Pennsylvania, Elverson
    2019 Tacoma TRD Sport DCSB 4X4 M/T Cement Gray.
    Stock
    When you have the MT all that down shifting with any slight grade or breeze you encounter doesn’t happen.
  6. Mar 4, 2019 at 5:31 PM
    #386
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Thanks for posting that up, my dealer said they would do the updated TSB tune, just need to take it in one of these days.
  7. Mar 21, 2019 at 3:31 PM
    #387
    OVTune
    OVTune Well-Known Member
    OVTune
    The differences / gains are not from ignition / fuel / or anything like that.
    From what I see the gains are from changes to valve timing on 04B04, and torque converter tuning.
    You'd be shocked how terribly low power will be if the torque converter isn't locking or unlocking at appropriate times.
    5500 likes this.
  8. Mar 21, 2019 at 4:01 PM
    #388
    Frank_Zuccarini
    Frank
    Chicagoland
    Very interesting, indeed. Thanks for the clarification.
    Frank
  9. Mar 22, 2019 at 11:08 AM
    #389
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    Pure pukey puke!!
  10. Mar 22, 2019 at 2:18 PM
    #390
    5500
    5500 Active Member
    Ed
    Cape Cod
    2019 Cement Sport
    Just read a number of posts in this topic. As with everything I've read regarding the 3.5s performance in 3rd gen Tacos, the difference in driver experience is quite interesting. I love my new Taco, but was very disappointed by initial performance and it doesn't seem to be getting much better with a reasonable amount of break in miles. Came from a 2013 FJ (4.0/5sp auto). Was very pleased with performance and mileage of that vehicle, especially considering it was about as aerodynamic as my house and a couple hundred pounds heavier than my Taco. Was expecting at least similar performance/mileage, given the 6 speed auto, lighter weight, and slightly improved aero. This engine/tranny/programming combo sucks for use in a truck.... period. I don't even find it particularly economical either driving it as intended leaving the tranny in D. I'm no engineer, but I know this truck isn't tuned to do work under 4K rpm, and the claimed mileage from Toyota was clearly achieved driving the EPA mileage cycle... not real world driving. As soon as I'm out of warranty I'm getting a tune. Until then, S4-S5 and minimum 89 octane fuel is the only way I can drive this thing with any sense of purpose.
  11. Mar 27, 2019 at 4:23 PM
    #391
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Fuck em.
    FiveByNine likes this.
  12. Mar 27, 2019 at 4:33 PM
    #392
    djgynee
    djgynee Well-Known Member
    Southern California
    2018 Magnetic Grey Metallic Tacoma DCLB TRD Sport
    Fucking well said bro. I found myself in there and was informed and now happier with knowledge
    FiveByNine and hiPSI[QUOTED][OP] like this.
  13. Mar 29, 2019 at 3:12 AM
    #393
    tacoma man
    tacoma man Well-Known Member
    Rochester NY
    2018 Limited 4wd Magnetic Gray
    Told like it is. "Some people are just fine with their truck the way it is." The truth, the whole truth, nothing but the truth so help you Tacoma.
    hiPSI[OP] and SilverBulletII like this.
  14. Apr 20, 2019 at 1:31 PM
    #394
    TacomaIvan19
    TacomaIvan19 Well-Known Member
    2019 TRD Sport
    Tailgate Inserts Black Weather Tech Mats Rekgen Mud Flaps
    Yeah, some guys with a MT can even complain about when it shifts! ;)
    2016Tacoman likes this.
  15. Apr 20, 2019 at 1:35 PM
    #395
    TacomaIvan19
    2019 TRD Sport
    Very Good Points. But with a few it seems they didn't even test drive the truck??
  16. Apr 20, 2019 at 1:40 PM
    #396
    whitepony04
    whitepony04 The Big Igloo is coming...
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    Eibach pro kit, 3 leaf aal, ecgs, fn fx pros, bfg ko2, gator sfx, Meso stuff
    I thought my taco would run 11’s stock. It’s a race truck after all. So disappointing.
    hiPSI[OP] likes this.
  17. Apr 20, 2019 at 1:50 PM
    #397
    TacomaIvan19
    2019 TRD Sport
    Hmmm, I dunno? The last engineer I had the pleasure of arguing with over the whole dock was wired wrong and I'm a Dam Engineer.. STFU'd when I simply pushed his plug in further and twisted it..
  18. Apr 20, 2019 at 2:02 PM
    #398
    TacomaIvan19
    2019 TRD Sport
    Yep, Hood Scoop is the ticket, but only when the bugs are all cleaned out of it!
    BC Hunter and hiPSI[QUOTED][OP] like this.
  19. Apr 20, 2019 at 2:06 PM
    #399
    TacomaIvan19
    2019 TRD Sport
    I have to agree, I really like it when I get into the pedal and it winds up to 6 grand nice and tight. Does feel and sound good. Nice Truck!
  20. Apr 23, 2019 at 6:32 AM
    #400
    atrain23
    atrain23 Well-Known Member
    Alex
    New Hampshire
    2016 Tacoma SR5 DCSB V6
    TRD off-road wheels
    I hated my Tacoma, until I started using ect power all the time. It fixed it for me. Now it keeps it in right gear to maintain speed up a hill without shifting up and down 6 or 8 times, that’s not an exaggeration either. My mpg are up also because I’m not always on the gas to make it be in the power rpms. The Ford Ranger is going to put a hurt on Toyota’s market share. It doesn’t look as good but comfort, power and tow capacity are just a 100% improvement, but we’ll see.
    MOC221_ likes this.
