Entering a truck pull?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FreidTaco, Jul 29, 2013.
  1. Jul 29, 2013 at 6:55 AM
    FreidTaco
    FreidTaco [OP] boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    So I have been tossing the idea around in my head about entering the truck pull. Next week Heartland truck and tractor pull comes into town. I want to do it just to see how well my pickup would do. BUT I really do not want to trash my pickup. I'll probably end up not doing it.
    Specs of my pickup
    06 w/ 6 speed
    3inch lift 33 inch duratracs
    URD stage 3 sc and all the fixins
  2. Jul 29, 2013 at 6:58 AM
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    Sounds like fun.. I wouldn't though. Both trucks will have the ability to pull the other, it's more a timing/size/traction issue but hey if you want to, I want to know how you do. :)
  3. Jul 29, 2013 at 7:01 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Need video if you do it!
  4. Jul 29, 2013 at 7:01 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I think he means more of a sled pull not truck on truck. But OP, I wouldn't. Not with a 6 speed. You'd do way more damage to your clutch than I think is worth it
  5. Jul 29, 2013 at 7:03 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, I wouldn't. All you might get out of it is bragging rights and there is a large potential for a sizable repair bill if things go poorly.
  6. Jul 29, 2013 at 7:06 AM
    majorhavok
    Mike in Cali..
    Lol.. whoops!
    I still wouldn't do it, but if he does I want to see video. :D
  7. Jul 29, 2013 at 7:12 AM
    FreidTaco
    jeff
    Yes it is the sled type. The truck on truck is just idiotic to me. And I unfortunately still have the stock clutch with my stage 3 supercharger. But if it did burn up it would give me a reason to get a better clutch haha. I was towing a 14, xxx lb tandem axle grain truck the other day to get some transmossion work done on the truck and that got me thinking about all this. The mechanic said my pickup souded like a 396 coming up the hill pulling that truck the he turned around and it was just a tacoma pulling a c60 tandem axle chevy. Haha
  8. Jul 29, 2013 at 7:16 AM
    NC15TRD
    Nick
    PA
    if you do it then you have to post a video or we will have a petition to ban your ass!
  9. Jul 29, 2013 at 7:19 AM
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    that's going to be extremely hard on the clutch, esp w/ the URD blower, those big diesels commonly run twin plate clutches etc, and can handle a little more stress. personally, I wouldn't attempt it
    however, if you do, universal consensus is that we ALL want to see vid
  10. Jul 29, 2013 at 7:28 AM
    FreidTaco
    jeff
    IF I would do it..... remember I said if.... what gear/range would be optimum?
  11. Jul 29, 2013 at 7:33 AM
    HighTQCummins
    Hank
    SE PA
    '12 SW DCSB Sport
    4low, maybe 2nd or 3rd gear, depends on how the track is hooking and how good your clutch is
  12. Jul 29, 2013 at 7:59 AM
    gwos25
    gwos25 Well-Known Member
    Gary
    Calgary, AB
    2012 TRD Sport
    Do it, take vid. :) Do it in 4hi, and try getting off the line in 1st, make the shift to 2nd quickly so you can gain momentum and complete the pull in 2nd, modulate the throttle/wheelspin to keep it out of the limiter and complete the pull in 2nd. Gearing wise, this should let you hit a wheel speed of 60mph without going into the red, and with the SC, you should have enough torque to keep it moving/spinning at lower speeds near the end of the pull, all without any abuse to the clutch. I have absolutely no experience with this, just saying, going in blind, that's how I would try it.
    Edit: Here's why I would use 4H with the 6speed. In 4L, you have a narrow speed range for each gear, so you will have to shift more often while gaining speed, and with each shift lose momentum. Given the Taco already has a big flat torque curve, made even better by the SC, I'd use 4H , get it in 2nd quick, and vary my speed/wheel spin using the throttle and RPM.
  13. Jul 29, 2013 at 8:00 AM
    FreidTaco
    jeff
    Ratio wise how does tgat compare to 1 hi
  14. Jul 29, 2013 at 8:30 AM
    FreidTaco
    jeff
    Shifting is almost not an option. You are pulling a sled that is getting heavier and digging more and more in the diet as you go. You would almost stop instantly if you tried to shift.
  15. Jul 29, 2013 at 8:30 AM
    gwos25
    Gary
    Calgary, AB
    2012 TRD Sport
    3rd 4L is almost the same as 1st in 4H.
    see here:
    http://www.grimmjeeper.com/
  16. Jul 29, 2013 at 8:37 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    He is running a centrifugal supercharger.... Not roots.
    Low end may not actually be the best for him...... Prolly more mid/higher rpm.... Dunno if that effects the gearing u had pplanned or not. Just pointing out the tq curve possibly won't be the same as roots style
  17. Jul 29, 2013 at 8:44 AM
    HighTQCummins
    Hank
    SE PA
    '12 SW DCSB Sport
    4th low would be similar to leaving a light in 2nd, sure you could get some clutch slip, but it'd take a lot of strain on the clutch, and by the time you got to the point where the clutch was full lock, sled would start getting heavy right away and drag you right down. take it slow, even if you are turning some rpm's, but don't let it bounce much, things will break quick
  18. Jul 29, 2013 at 10:39 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
  19. Jul 29, 2013 at 10:47 AM
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    Shes really excited about furniture....
  20. Jul 29, 2013 at 10:51 AM
    metrick1215
    Habersham GA..
