Entune Advantage?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by STrooper, Mar 17, 2019.
  1. Mar 17, 2019 at 9:27 AM
    STrooper
    STrooper [OP] For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    Hello everyone, I have a 2018 Sport and haven’t registered to Entune as of yet since I mainly been using the Bluetooth. Is there any advantage on doing so? Am I missing any good features etc? Can I unregistered if I don’t like the updates and have the HU back to stock?
    Any feedbacks, suggestions would be gladly appreciated!:thumbsup:
  2. Mar 17, 2019 at 9:34 AM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    I don’t think using all the features changes the head unit. It just makes more apps available when logged in and connected. Not logged in, those features aren’t available, and everything else is the same.
  3. Mar 17, 2019 at 9:40 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I installed the app, it adds iheart radio and slacker. then gives you some other GPS functions. I found all to be useless. If you unistall the app, iheart radio and slacker will still be in your options menu and you have to click through them to get back to FM or bluetooth.
    To remove iheart radio and slacker, you have to remove personal settings. This will clear most things, and you will have to redo your radio settings (pair phone, set up presets)
    PRO-TIP: if you dont use XM, and dont want the icon anymore, remove the radio and unplug the XM module. Its the box on the bottom of the radio with the brown plug on it.
  4. Mar 17, 2019 at 10:38 AM
    STrooper
    Jack
    NC
    Good info guys! By registering, does the HU keep up with the latest updates or any important notification etc as well?
  5. Mar 17, 2019 at 10:55 AM
    5nahalf
    Erik
    Minnesota
    Updates are few and far between, your not gaining anything from it aside from iheart radio and slacker
  6. Mar 17, 2019 at 11:01 AM
    STrooper
    Jack
    NC
    Can I ask, what is slacker?
  7. Mar 17, 2019 at 11:05 AM
    erok81
    erok81 Well-Known Member
    Imposter
    Sometimes I use the navigation search feature to set my destination. That you need to log in.
    However I’d say 90% of the time I don’t use it because for some reason I have to log in every time I want to.
  8. Mar 17, 2019 at 11:06 AM
    5nahalf
    Erik
    Minnesota
    internet radio.
    Everything you do with the entune app can be done just with bluetooth. entune app just puts the interface on the headunit instead of the phone.
    Since I use google play music, these options were useless for me.
  9. Mar 17, 2019 at 11:09 AM
    STrooper
    Jack
    NC
    Are you able to see text msgs on the tachometer or HU?
  10. Mar 17, 2019 at 11:10 AM
    5nahalf
    Erik
    Minnesota
    You can do that anyways I beleive
