entune compatible iPhones
Discussion in 'Audio & Video' started by JoshuaWCorry, Dec 24, 2017.
  1. Dec 24, 2017 at 8:13 AM
    JoshuaWCorry
    JoshuaWCorry [OP] Member
    Josh
    2017 Toyota Tacoma TRD SPORT
    Hi all
    Apologies if this has been posted but I don't think it has. I have a 2017 trd sport upgrade package that I picked up on Wednesday. I have connected it to bluetooth and have no problem making phone calls. When I have gone to set up messaging I am having problems. I have gone into my settings on my iPhone and have put show notifications on. It still is not working. Is my iPhone compatiable?
    Its an iPhone 6se
  2. Dec 24, 2017 at 9:51 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    My 6S works fine... wish I could help you out with the settings.
    SB
  3. Dec 25, 2017 at 12:54 PM
    JoshuaWCorry
    Josh
    Actually its an SE. was it simple to set up?
  4. Dec 25, 2017 at 12:55 PM
    alf
    alf Well-Known Member
    Alf
    Houston
    TRD OR 4x4
    Messaging is annoying anyway. You don’t really need it.
  5. Dec 25, 2017 at 1:00 PM
    Tacos4ever15
    Tacos4ever15 Well-Known Member
    2015 Pyrite Mica Tacoma TRD Off-road 4x4
    Did you look in the Bluetooth settings, turn it on in there. Hopefully that will work for you, someone with a 17 will be able to answer you better. Good luck.
  6. Dec 25, 2017 at 1:01 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Many of us HAD issues in the past. I forget at what iOS update all of my issues disappeared but I was under the impression that the situation was solved. I wish I could give you a solution but do search of the site and maybe there is something I have overlooked.
  7. Dec 25, 2017 at 1:07 PM
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    Depends on what messaging not working means. The Entune system will only notify you that a message exists if the truck is moving, and will not put the text on the head unit while moving, it only gives you the option to have the Entune unit read the message aloud.
  8. Dec 25, 2017 at 1:09 PM
    coma toy
    coma toy Off Road Taco
    Wow, that's perfect!
  9. Dec 25, 2017 at 1:25 PM
    baron55
    Well some want the full texting/messaging functionality as if you had your phone in hand.
    That will never happen, due to the class action liability for cause in fatal texting accidents.
  10. Dec 25, 2017 at 1:28 PM
    Sagebrush
    Gens 1, 2, 3, and 4
    Yep. A couple of months ago there was an IOS update and I had to go into settings and tweak something or other. Wish I could recall what it was.
    SB
  11. Dec 25, 2017 at 6:51 PM
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    I had a different issue today while trying to get my contacts in my new(to me) radio. when I switched the "Sync Contact" to on --it then worked. there is another setting right next to the sync called "show notifications" ?? Maybe?
  12. Dec 25, 2017 at 6:52 PM
    Sagebrush
    Gens 1, 2, 3, and 4
    That's sounded very familiar.
    SB
