Entune Issues, Tips, Tricks, Updates Lets hear them
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elytravis, May 1, 2012.
  1. Feb 17, 2014 at 4:30 PM
    #421
    jptx65
    jptx65 Member
    Jeff
    The Woodlands, Texas
    2013 PreRunner SR5
    Bilstein 5100's Front and Rear Hellwig Rear Sway Bar ImMrYo Rear-View Mirror Lift Bracket Katzkin Leather Seats
    I use the Pandora app on my iphone via bluetooth (sounds better to me) and it would pause whenever I connected to the built-in USB for charging. Now I use a flush, dual USB 12V adapter instead. It's also powerful enough to charge an ipad. My only complaint is that the 12V socket cover is ugly when open all the time. I may try to remove the cover at the hinge.
  2. Feb 17, 2014 at 5:21 PM
    #422
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Hmm, so I guess the behavior is intentional on Toyota's part. Still doesn't make sense to me, but I guess I'll have to live with the workarounds. I have one of those 12V USB chargers from my old car. I was hoping I could just use the built in USB jack because, like you said, the open socket is an eye sore.
  3. Feb 18, 2014 at 3:06 PM
    #423
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    Last night I upgraded the ROM on my Android from JellyBean to KitKat and now my messaging via Entune works. Just a heads up for other Android users.
  4. Feb 18, 2014 at 3:52 PM
    #424
    tacotacoburrito
    tacotacoburrito Well-Known Member
    That might not last. Did the same and messaging started working. Then my phone a week later started refusing to pair with the HU. I deleted the phone from the HU and repaired. Hasn't worked since.
  5. Mar 2, 2014 at 4:05 PM
    #425
    Ryudagr8
    Ryudagr8 Member
    Az
    4x4, 4.0L
    I installed a sub and an amp to my entune system and now the XM Radio button on the "Audio" section of the touch screen is gone. I have no clue what to do? please help if you have ever had this problem or have any clue on what to do. I have tried to figure out how to reset it or update the entune but have had no luck finding the zip file. Its a 2014 taco. the number on the entune is 57090, I'm assuming that is the model number of it.
  6. Mar 2, 2014 at 4:54 PM
    #426
    sonic77
    sonic77 Well-Known Member
    Justin
    Peoria IL.
    2013 Magnetic Grey 4x4 TRD
    None Yet!
    Did you add a line level convertor for your RCA connectors on the amp? Or hook up to the wrong wire for remote turn on Maybe you tapped into the wrong wire
  7. Mar 2, 2014 at 5:32 PM
    #427
    Ryudagr8
    Ryudagr8 Member
    Az
    4x4, 4.0L
    yes I added the convertor for the rca's from the amp, but I wish I had a diagram for all the wires. Just to make sure i didnt hook up the wrong wires.
  8. Mar 2, 2014 at 6:08 PM
    #428
    sonic77
    Justin
    Peoria IL.
    None Yet!
    Try disconnecting what you hooked up there's diagrams out there just takes time to find the right one
  9. Mar 3, 2014 at 8:23 PM
    #429
    ThatguyJZ
    Jim
    TRIAD, NC
    You're right... having issues now. One being that when I would receive a message the whole head unit would reboot. I'm running SlimKat.
  10. Mar 9, 2014 at 6:11 PM
    #430
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    OK. I did a '14 non JBL w/ Entune & nav.
    EVERYTHING works, but I cannot figure out how to physically connect my iPhone with entunes.
    I sourced a VIN from FLtrucks, it worked with creating the account on my phone, but it will not let me connect to the vehicle.
    Any ideas?
  11. Mar 9, 2014 at 10:17 PM
    #431
    DesertBighorn
    DesertBighorn Active Member
    Doug
    WA
    14 DCLB 4x4 MGM
  12. Mar 10, 2014 at 10:02 PM
    #432
    sonic77
    Justin
    Peoria IL.
    None Yet!
    Your iphone won't connect with entune unless you plug your phone into the USB port with your lightning to usb plug make sure entune is installed on your phone and open it one your plugged in it will ask you if you want to enable the phone for internet click yes then your set enjoy
    I had same issue when I went from a android to iphone my android didn't need any cable to make it work but I hated the phone my iphone is awesome this is the only negative point so far but I guess it charges my phone so that's ok
    Hope this helps
    Justin
  13. Mar 11, 2014 at 1:58 PM
    #433
    Milan
    Milan Member
    Just upgraded my 2012 from 2.1 to 3.2. Upgrade process worked flawlessly. Thanks. I haven't noticed a difference but I don't use it to it's full potential either.
  14. Mar 11, 2014 at 2:57 PM
    #434
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
    I'm running KitKat as well and my messaging is not working, still.
  15. Mar 11, 2014 at 9:25 PM
    #435
    steveo27
    Pittsburgh
    No shit?! I thought it connected via bluetooth. Damn I feel silly.
    Ill have to try again after work tomorrow.
    Thanks for the heads up.
    :beer:
  16. Mar 12, 2014 at 9:55 PM
    #436
    steveo27
    Pittsburgh
  17. Mar 12, 2014 at 10:16 PM
    #437
    EatMeImATaco
    EatMeImATaco Well-Known Member
    Portland, Oregon
    2014 DCLB TRD Sport 4x4
    07MAR14 - Husky 3-piece floor liners 07MAR14 - AVS 4-piece in-channel air vents 07MAR14 - Clear Bra 15MAR14 - Extang BlackMax Tonneau (Removed) 11APR14 - MetalTech Rock Sliders 11APR15 - Sport Hiline SnugTop Shell + Sportsmen Package 24JUL17 - CalKing seat covers 02OCT17 - OME 2886 Shocks and Coils, & leaf replacement 04NOV17 - Maglite Mount 18FEB18 - SPOD install 18MAR18 - CKMA12 in Engine Bay 21APR18 - SSO Hybrid Slimline with Smitty X20 10k and Heisse combo bar 13MAY18 - Relentless Pod mounts, Mictuning pod lights 13MAY18 - CB Radio with external PA 03JUN18 - Sleeping platform with drawers and marine carpeting
    Has anyone figured out how to delete preset stations rather than just over write them?
  18. Mar 13, 2014 at 5:05 PM
    #438
    TacoBully
    TacoBully Well-Known Member
    CJ
    RI
    2014 4X4 Access Cab
    I have a 2014 AC and I am trying to figure out how to get Pandora to work. I press the Bluetooth Audio button as a source and nothing happens. It just brings up the settings screen that asks me if I want to access my phone as both a phone and as the source of my music. Um. Yeah. I do.
  19. Mar 14, 2014 at 4:39 AM
    #439
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    disconnect the battery is the only way :)
  20. Mar 14, 2014 at 5:18 AM
    #440
    bear263
    bear263 Well-Known Member
    Florida
    2013 PreRunner TRD SP
    LED interior lights. Steering wheel mod. New radio. Amp, speakers and sub woofer.
    On my '13, you don't use the bluetooth button. You go to apps and choose Pandora. The radio will then connect to the internet through your phone as long as the entune app is running on the phone.
