Entune Issues, Tips, Tricks, Updates Lets hear them
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elytravis, May 1, 2012.
  1. Aug 2, 2014 at 2:47 PM
    #521
    Yakoma
    Yakoma Well-Known Member
    Randy
    ATL-ish
    '14 DCSB TRD Sport 4x4 - White
    Black APS Bull Bar Black Westin Step Bars Black ARE camper top with Yakima J-cradles (replaced Roll-X Tonneau) Black AMP HD Bed Extender
    Sorry to hear you confirm my fears since I think this means I'm SOL until Entune comes up with an update - and even then I'm not confident. Yes, using the same USB port. I don't have the Nav, but same issues.
    I tried going to the thumb drive, but that loses all the display metadata on the screen so that's a bad option.
    There's definitely an issue with the connection because jiggling it will cause problems, but I don't think it's limited to just the connection either.
    I wonder if others with different iPods are getting this issue?
  2. Aug 3, 2014 at 5:07 AM
    #522
    G8keepr
    G8keepr Well-Known Member
    Rich
    North central mass
    2017 TRD OR
    Maybe time to upgrade the iPod!. My iPod 5th gen no problems. iPhone 5s works great too. Even the ipad connects perfect.
  3. Aug 3, 2014 at 8:31 AM
    #523
    Yakoma
    Randy
    ATL-ish
    That's good to know...I've got an iPhone 5s. Do you connect via USB port or do you use Bluetooth? I definitely don't want to drop big $$ on another iPod unless I'm sure it works, you know?
  4. Aug 3, 2014 at 1:11 PM
    #524
    G8keepr
    Rich
    North central mass
    2017 TRD OR
    I use both connections. Usually Bluetooth. Yea iPods aren't cheap. I've won two 32G out of a kids game at the arcade, for $30.
  5. Sep 21, 2014 at 9:01 AM
    #525
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    So my 5000 mile Tacoma entune radio keeps resetting a couple times within each hour.
    Yesterday I changed stations and all radio sound went out. CD worked Bluetooth worked just no radio sound both am and FM. Sounds like this is normal.
    Do your replacement radios do this also?
    Entune plus no navigation
  6. Sep 21, 2014 at 9:03 AM
    #526
    jmaack
    Justin
    Helena Alabama
    Also once I shut truck off turned it back on sound was back working.
  7. Sep 21, 2014 at 10:29 AM
    #527
    LarryM04
    LarryM04 Well-Known Member
    Dayton, TN
    2014 BRM DCSB TRD Sport
    I think you should bring this to your Toyota service center for replacement. Mine's never reset.
  8. Sep 21, 2014 at 11:13 AM
    #528
    jmaack
    Justin
    Helena Alabama
    Taking in this Friday. I have heard they replace them but can't find any threads about if the replacement ones fix it or if they will eventually do the same thing.
  9. Dec 11, 2014 at 5:13 AM
    #529
    mikecoscia
    mikecoscia Well-Known Member
    New Jersey
    2015 TRD Pro
    I'm having issues getting my messages to sync. Everything else works fine. I have an iPhone 6 on Verizon's network and the correct settings are all checked off. Tried re-paring the phone several times and nothing has worked. Anyone with the same issue?
  10. Dec 11, 2014 at 5:20 AM
    #530
    Bentrodder
    Bentrodder PeeRunner Fanboy
    Peter
    Cotati, CA.
    2015 DCLBFTMFW TRD Sport
    Kings and a TW DECAL!!!
    I had this problem with my 6 also. Once it is paired via Bluetooth, go into message settings and switch on get notifications. You only get that option if it is paired with Bluetooth. This worked for me.
  11. Dec 11, 2014 at 7:28 AM
    #531
    Yakoma
    Randy
    ATL-ish
    +1
    Same thing worked for me with my iPhone 5.
  12. Dec 11, 2014 at 11:54 AM
    #532
    mikecoscia
    New Jersey
    2015 TRD Pro
    Already have it checked off. Oddly, I receive text messages while driving. However, it is not promoting me to read them and any prior messages on my iPhone are not being synced up. Phone calls and apps work fine via voice.
  13. Dec 11, 2014 at 12:18 PM
    #533
    Yakoma
    Randy
    ATL-ish
    I don't think it supports prior messages, or at least I've never seen them. Prompting to listen to them is intermittent, IIRC.
    Entune is buggy and this is one of them.
  14. Dec 20, 2014 at 2:17 PM
    #534
    elytravis
    elytravis [OP] Well-Known Member
    Travis
    Always changing...but there is no place like home.
    2012 Nautical Blue DCLB TRD Sport
    Black tube steps, Skid plate, Bilstein 6112's front and 5160's rear, Bakflip F1 folding cover, EGR raingaurds, All weather floor mats, AFE pro dry filter, BFG 265 70 R 17 KO2's.
    Entune 3.2
    https://drive.google.com/file/d/0B0-itbICX-ePb196RTBDVlRlVkU/preview?pli=1
    Haven't had time to install yet, my truck is in the shop. Let me know if this works
    I didn't realize that my Entune version was old. The download and self install did not work for me but I went to my dealer and they were able to update me to 3.2 for free. No major changes, just subtle tweaks.
    3.2.0 fix details
    Some 2012 – 2014 model year vehicles equipped with a Display Audio Navigation System (Non-HDD)
    and Entune™ (version less than 3.2.0) may exhibit one or more of the following conditions:
    • Roads flash on and off in certain zoom levels (when Entune is in use)
    • Discolored bands appear across the screen (when Entune is in use)
    • Map area on the screen is black and only buttons are visible (when Entune is in use)
    • Navigation freezes (when Entune is in use)
    • When Bluetooth is the last audio mode selected in previous ignition cycle, audio source switches
    back to Bluetooth when another source is selected immediately after the engine starts
    Updated system software is now available to address these conditions.
  15. Dec 24, 2014 at 11:12 AM
    #535
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    15 TRD Sport (DCLB-BRM) - 88 ///M3 (Zinnoberrot)
    OME 887/Dakars/NV305s/33" Duratracs/+
    Read about the Entune update, gonna try it out
  16. Jan 10, 2015 at 2:22 PM
    #536
    Yakoma
    Randy
    ATL-ish
    I've got the non-Nav head unit in a 2014. Is there an Entune update for this any newer than 2013? I couldn't apply the above update to my unit.
  17. May 22, 2015 at 10:05 AM
    #537
    elytravis
    Travis
    So far it seems that my in dash system is lacking. With the gps update around $180 and the map getting me lost at an interchange passing through Virginia on a1000 mile trip, I am intrigued to see what I can install in its place. Entune was a great start but the 14's and later seem to be getting better options (as they should). I'm beginning to want something better and hesitant to start the $180 map upgrade if I can upgrade the entire system. I'm often hesitant to go aftermarket because sometimes it looks cheap after install. Any suggestions?
  18. May 22, 2015 at 2:46 PM
    #538
    Quadsix
    Quadsix Well-Known Member
    Don
    Bonaire, Georgia/Palm Bay, Florida
    12 Quadcab TRD Sport Upgrade
    K&N Intake Filter, K&N Cabin Filter, Redline Hood Struts, Tailgate Mod, Wet Okole Seat Covers, WeatherTech rain visors/digital floor mats, 6K HID headlights, 4300 HID fog lights, Westin Bullbar, Westin side steps, Westin Bull Bar, Westin Quadrant LED Aux Lights, Bed mat, Rocky Mount Clutch SD Bike Mounts, LED Bed lights, Blue LED shift indicator
    They really should sell these as a GB or some place. I have been trying to make one of these that will last. I used plastic before, but it wouldn't stay mounted. So back to the drawing board again.
  19. May 22, 2015 at 11:07 PM
    #539
    Michael Craven
    Michael Craven New Member
    2014 Toyota 4runner Limited
    I have a 2014 4runner Limited.
    To get my 160Gb Ipod 5th gen with the newest firmware to work - I had to reduce my song count to under 10,000 - then - NO MORE PROBLEMS! Hope that helps somebody out there!
  20. May 25, 2015 at 7:25 PM
    #540
    oucheese
    oucheese Well-Known Member
    The other day was routing my way back home and had the navigation app on full screen, the screen kept going back to my home screen. (Split between the radio and navi) Is there anyway I can turn just one single app on for full screen??
