Entune Radio swap -Successful --"ALMOST"
Discussion in '3rd Gen. Tacomas (2016-2023)' started by markmizzou, Dec 23, 2017.
  1. Aug 25, 2018 at 6:25 PM
    markmizzou
    markmizzou [OP] Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    is your truck a 4x4?
  2. Aug 25, 2018 at 6:27 PM
    markmizzou
    Mark
    Missouri
    Also I think it has to have the Nav SD card inserted/installed
  3. Aug 25, 2018 at 7:15 PM
    5staight
    5staight Active Member
    17sr5
    Ya I had the stand radio with scout and it is a four week drive. I will have to check the connections on the back tomorrow the X m radio does work.
  4. Aug 25, 2018 at 7:17 PM
    5staight
    17sr5
    And it does have a sd card I checked that right off.
  5. Aug 26, 2018 at 4:56 AM
    Gator352
    Gator352 I like Publix cake ...
    Leesburg, Florida
    2018 Super White Tacoma SR5 4x2
    I’m also looking into replacing my Entune audio plus with the premium or JBL version. I have to keep it pretty much stock as my truck is leased and want to keep it that way so there’s not any problems. So if I have the dealer do it, how many kids do I have to sacrifice?
  6. Aug 26, 2018 at 8:57 AM
    markmizzou
    Mark
    Missouri
    Depends on the "quality" of the kids!
    No seriously --you better be ready to open up your wallet VERY WIDE as a lot of green will fly out.
    The price the dealers want to charge for these head units will floor you, to say nothing of "them" doing it for you. I checked out the prices from the dealer wanted for just the unit , and I was shocked -- over $1200; for the premium -- not the jbl. Oh and don't forget you will need a new dash surround part. I bit the bullet on the surround and bought it from a dealer in another state for around $200. Then I sold the radio and the surround I took out - so that eased the pain somewhat!
    JohnDeere55 and Gator352[QUOTED] like this.
  7. Aug 26, 2018 at 9:04 AM
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
    Probably don’t want to mess with the JBL as they are significantly different. Just go with the standard premium.
    Gator352 likes this.
  8. Aug 26, 2018 at 9:30 AM
    Gator352
    Leesburg, Florida
    Thanks guys! I might go with the premium and surround and do it my self. I’m not radio “illiterate” as I’ve installed many but dayum, dealerships are legal highway robbers!
    Pickupman2007[QUOTED] likes this.
  9. Aug 27, 2018 at 5:02 PM
    5staight
    17sr5
    I didn’t pug in the antenna for the gps now working so entune to entune premium is pretty much plug and play
  10. Sep 1, 2018 at 5:24 AM
    JohnDeere55
    JohnDeere55 Member
    Sandown, NH
    2018 Tacoma Limited Double Cab
    AR914 20x8.5 wheels, Toyo 285/50/20 Proxes S/T, Westin 3" bars, PowerBass speakers
    This reply applies to my experience with the Toyota/JBL audio system in my 2018 Tacoma Limited.
    Like most everyone else, I found the JBL system underwhelming, very underwhelming even though the dealer used it as a selling point, that "this Tacoma comes with the top-of-the-line $2300 JBL audio system." Riiight …
    The first thing I did was to replace the stock JBL speakers with PowerBass speakers at the recommendation of Crutchfield in order to be compatible with the JBL 2 ohm system. I found it incredulous that JBL would put their name on those crappy stock speakers. The PowerBass speakers were a definite improvement but not what I was expecting, so sent them back and instead ordered JBL Stadium GTO960C speakers for the front, and JBL Stadium GTO620 speakers for the rear. Even though the Stadium speakers are rated at 2.5 ohms, the small reduction in volume was worthwhile; they sound great, and better than the PowerBass speakers.
    I didn't find out until I tore into the fronts that the signal delivered to the front doors is filtered, so connecting the stock front wires to the crossovers that came with the Stadium speakers didn't provide a usable signal to the tweeters; it also short-circuited my plans to leverage the 3-way capability of the crossovers that came with the Stadium speakers to connect the JBL GTO20M mid-range speakers. Instead, and because I did not want to replace the stock tweeters as they seemed decent, I ran a new set of wires from the stock tweeters in the dash down and out to the doors where I connected the Stadium tweeters in parallel, and surface mounted them to the front doors; they fit perfectly and are unobtrusive. However, after further research, I'm a little concerned with the reduction in impedance on the stock amp tweeter channel as a result of having wired the new tweeters in parallel … No issues yet, a week later, after running the system at max volume a good amount of the time but, still a little concerned.
    Yesterday, I replaced the stock JBL subwoofer with a Rockford Fosgate Punch P3SD2-8 subwoofer, connecting it directly to the stock JBL amp. That was a huge improvement over the stock JBL sub, even without inserting a mono amp in-between. I have a Kicker PXA200.1 amp on order that can deliver 100 watts @ 1 ohm, and the Rockford sub can be wired for 1 ohm, so there's plenty of room for further improvemnt, if needed. However, I'm going to live with the system as is for a week or two to see whether I really need/want to install the Kicker amp.
    Overall, the quality of sound with the work done thus far has been a tremendous improvement. I think I could easily live with what I now have for the next several years that I'll own the truck.
  11. Sep 1, 2018 at 7:01 AM
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    Is it just a drop in speaker replacement in the existing enclosure? Any pics? Do you know what the stock wattage for the JBL amp is to the sub and how many ohms?
  12. Sep 9, 2018 at 7:04 PM
    JohnDeere55
    JohnDeere55 Member
    Sandown, NH
    Yes, for the Rockford Fosgate Punch P3SD2-8 subwoofer, it was a simple drop in, though drilling new holes for the screws is necessary. Piece of cake, really.
    I didn't compare specs but, I think that any of these would drop right in so long as you take the ohm rating into consideration …
    https://www.crutchfield.com/g_446250/8-Inch-Subwoofers.html?tp=68848#&nvpair=FFSize|[rank16]8"&nvpair=FFTop@mount_Depth|[rank1]Less than 3%22
    No photos, sorry, but not really needed for as simple of a replacement as it was if the replacement sub is connected to the stock JBL amp. Toyota/JBL publish the watts at 440 but, there's not a RMS watts spec to be found; lots of us have searched. However, I've talked to a few people and the estimate is 200 watts RMS. The system is most often spec'd as 2 ohm, and I believe that is correct. However, I installed JBL Stadium speakers rated at 2.5 ohms in the front/rear doors, and they are just perfect; only a very small loss in volume.
    https://www.jbl.com/automotive-toyota.html
    I ended up installing the Kicker PXA200.1 amp configured for 100W at 1 ohm; finished up this morning … It was more involved than simply connecting the sub to the stock JBL amp but, I'm glad I did. I can't believe the difference … It's only an 8" sub and a relatively small amp but, I could not be more pleased. Rather than having the bass setting on the head-end set to max under purely stock conditions, and even at that the bass coming from the stock JBL sub being pitiful, now I have the setting in the middle, with plenty of up-side range when needed. And that's with the 6db bass boost on the Kicker amp disabled !
    Double Phister likes this.
  13. Sep 10, 2018 at 6:51 AM
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    The fact that you can so easily go between the different audio head units and have it be plug and play makes me wonder if they bring CarPlay and/or Android Auto in a year or two if we'll be able to just swap in the new head unit and have it 100% working. That would be nice, it is the only thing really missing I think from the truck that I want.
  14. Sep 10, 2018 at 8:14 PM
    markmizzou
    Mark
    Missouri
    Really? -- I would bet "they" are "ahead" of this. They will change something to make it difficult. Sorry to be a pessimist.
  15. Apr 11, 2019 at 2:57 PM
    #35
    bullyd
    bullyd Member
    Pete
    Garrison, NY
    2017 Tacoma SR
    Grill, wheels, running boards, fog lights, speakers, tonneau
    I'm doing the same thing Saturday. Swapping the base Entune radio for a premium. I ordered the larger bezel and a GPS antenna. My base model doesn't have Sirius XM. Did you already have Sirius? If not, how did you hook up an antenna? Is there an antenna prewired? I have a '17 SR. Thanks
  16. Apr 11, 2019 at 7:29 PM
    #36
    markmizzou
    Mark
    Missouri
    I have a SR5 with the Sirius so the antenna and wiring was already there. On the SR's I am not sure. AS I later learned , the antenna is no big deal. They can be had on Amazon and wired right into the back of your new (to you) head unit. I believe the antenna can be simply tucked up in the dash cavity and it works well.
    I did exactly what you are doing (except for the antenna thing and have been happy ever since.
    Good luck and make sure you get ALL of the connections hooked up.
  17. Apr 12, 2019 at 10:09 AM
    #37
    bullyd
    bullyd Member
    Pete
    Garrison, NY
    2017 Tacoma SR
    Thanks so much for the response! Excited for the install tomorrow.
