Entune Radio w/ Navigation for Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CC357, Jan 27, 2020.
  1. Jan 27, 2020 at 5:55 PM
    CC357
    CC357 [OP] New Member
    2020 Tacoma Off-Road
    I recently purchased a 2020 Off-Road with the standard radio (non-Nav and Non-JBL). I found a
    TOYOTA TACOMA 3rd Gen GPS NAV RADIO ENTUNE PREMIUM HEAD UNIT for a reasonable price and was wondering if it would be compatible with the 2020. The radio Model No. is: 86100-04181.
    Any help or info would be greatly appreciated!
  2. Jan 27, 2020 at 5:58 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Don't do this, you already have a good radio, carplay> Toyota GPS. Plus it won't work the connections for the earlier 3rd gen radios are different
  3. Jan 27, 2020 at 6:00 PM
    CC357
    Thanks for the quick reply and good info. I'll leave it as it is!
  4. Jan 27, 2020 at 6:00 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    I think the 2020 plugs are slightly different. You would need to stay with a 2020 Premium. If you can, Look at the sticker on the back of the HU. It has a date on it.
  5. Jan 27, 2020 at 6:02 PM
    CC357
    The date on the back of the unit says manufactured June 2017. Thanks!
  6. Jan 27, 2020 at 6:02 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    It fits and would work. BUT the wiring harness is different and “to my knowledge” no one makes an adapter harness. So while doable, you’ll be doing a ton of research to make your own harness and sourcing connectors.
  7. Jan 27, 2020 at 6:04 PM
    CC357
    Thanks all! With that knowledge, I'll leave well-enough alone. I don't want to get into a rewiring debacle.
  8. Jan 27, 2020 at 6:05 PM
    mutely
    a couple of antenna and XM receiver connectors are the same. vast majority are different.
    PhenixFord[QUOTED] likes this.
  9. Jan 27, 2020 at 7:17 PM
    PhenixFord
    Randy
    Arkansas
    I would guess that they also have a different Comms Protocol. You may be able to get it to work with some wiring ingenuity. But no steering wheel controls or dash display. Just a thought.
