entune randomly shutting off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by B22wheeler, Dec 2, 2015.
  1. Dec 19, 2015 at 10:34 AM
    rayban1
    rayban1 Well-Known Member
    Seattle
    2015 tacoma sport 4x4
    truck covers usa roll cover, popnlock remote lock, iron cross running boards, p2 trailer Brake, rear view mirror upgrade with auto dim temp and homelink, yakima rack bars , goodyear wranglers, heated side mirrors with directional signal.
    My 2015 did this the other night, seems like it started for some of us around the same time, any idea if you can do a update yourself or do you have to bring into dealer.
  2. Dec 30, 2015 at 8:19 AM
    broders
    broders Well-Known Member
    NC
    2016 Toyota Tacoma TRD Sport DCLB
    So I had a appointment on Monday 12/28 and dealer said there are currently no updates available and since they couldn't re-create the problem there is nothing they can do! Talk about a waste of 2 hours...I woke up early for that damn appointment too!!
  3. Dec 30, 2015 at 9:02 AM
    2016TacomaTRD
    2016TacomaTRD Part time Ninja
    2016 Tacoma TRD Sport
    I am about to do the same next week. This will be the 2nd time i will be wasting my time. Corporate case manager says I have to take it back so that they can re-create the problem. Already showed them 2 videos of it booting back up while driving. I just could'nt grab the phone quick enough when it shuts off.
  4. Dec 30, 2015 at 1:24 PM
    02TacoBro
    02TacoBro Well-Known Member
    Houston, TX
    2012 TRD SPORT 4WD, 6 SPD Manual, 3DR
    1.5" Suspension Lift Android Auto / Sound System GettaGrip Shifter
    someone should set up a dash cam but have it view the system when it does it..
    mine has done this once and it did it 3 times in a row and never happened again. 2k miles right now
  5. Dec 30, 2015 at 6:00 PM
    spp
    spp OC, Kalifornia
    OC California
    My 2015 did this before Xmas a couple times. I ejected the SD card while it was on and re- inserted and have had no issues SO FAR.:fingerscrossed:
  6. Jan 1, 2016 at 6:37 PM
    krazyscot
    krazyscot Active Member
    Stuart
    Colorado Springs
    Picked up our Tacoma ORSB 2 days ago, had this issue 3 times driving home from dealer, and once today (200 miles on the odometer now). Had no issues all day when the phone was charging through a usb adapter into the 12v socket, but it restarted after I'd moved the phone onto the USB/AUX so perhaps this is where the issue lies? I initially thought it was doing updates from dealership, but will keep an eye on it before running back to dealer.
  7. Jan 3, 2016 at 8:50 AM
    999crazy
    999crazy Active Member
    2016 Tacoma
    Mine has done it 3 times in about an hour it was when a friend had his iPhone plugged in via usb and was using his phone. No other issues or incidents. ?
  8. Jan 5, 2016 at 5:30 PM
    sbmon
    sbmon Well-Known Member
    This is normal. If you plug in via the USB the input mode will switch from Bluetooth to the hardwired source. I don't like the fact that it does this though. In my opinion a Bluetooth connection should remain connected and the input source mode should not change unless changed on the mobile device or head unit.
  9. Dec 11, 2019 at 5:07 PM
    jdbrunt
    jdbrunt Member
    2014 Tacoma TRD DBL Cab 4x4
    Sorry to resurrect an old thread but.....
    wondering if anyone knows if a firmware update for the gracenote software fixes this issue?
    I have same issue on my truck, wouldn’t mind fixing it if possible.
