Entune touchscreen auto day/night mode
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wsutaco, Nov 29, 2018.
  1. Nov 29, 2018 at 5:52 AM
    wsutaco
    wsutaco [OP] Well-Known Member
    18 TRD ORDCSB
    is there any other way to switch the entune touchscreen from day to night mode besides the button in settings>display? I find it kind of annoying it doesn’t go to night mode automatically when you turn on headlights or something. In the 4runner there’s a brightness wheel that changes all inside dash lighting brightness, if only the Tacoma had that. Thanks.
  2. Nov 29, 2018 at 5:59 AM
    danwray
    danwray Traitor
    Dan
    Kentucky
    2021 Ford F150 XL 4x4 2.7 ecoboost
    Mine dims when I turn on the lights. I've never messed with the settings for it, maybe when you do it manually through there, it disables it doing it with the lights.
  3. Nov 29, 2018 at 6:15 AM
    Gator352
    Gator352 I like Publix cake ...
    Leesburg, Florida
    2018 Super White Tacoma SR5 4x2
    Mine dims when I turn on the head or marker lights. I think it’s like that too using just using driving lights. But it does have a dash light brightness/dimmer. The little black thing protruding out the cluster panel... turn it right for brighter and left for dimmer.
  4. Nov 29, 2018 at 7:57 AM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    If I understand your correctly, your comment refers to switching the colors to day/night vs. just auto adjusting the brightness.
    I believe the responses above refer to the brightness, not the color scheme on the maps etc.
  5. Nov 29, 2018 at 8:04 AM
    Gator352
    Leesburg, Florida
    I think I read it correctly? He mentions that the brightness of entune isn’t changing when he turns On his headlights. There’s a setting in entune I believe. But he mentions dash lighting brightness and wished the taco could do that. It does with the little black thing sticking out of the cluster.
  6. Nov 29, 2018 at 8:13 AM
    The_Devil
    E
    Apologies. Mind blown here.
    My experience has been that the colors require manual switch, the brightness is tied to headlight switch.
    Hmmmmm. I need to figure out how to get it to auto switch, or find out why mine is malfunctioning.
  7. Nov 29, 2018 at 8:17 AM
    wsutaco
    18 TRD ORDCSB
    On mine the black thing sticking out only changes the color of the multi function display in the dash. The rpm and speed doesn’t change brightness. Only turns on when headlights or 3rd light setting is on, but the DRL is on the gauge cluster is dark. Also DRL makes it so that the entune touch buttons are brighter, but on 3rd light setting or headlights they are darker.
  8. Nov 29, 2018 at 8:23 AM
    Gator352
    Leesburg, Florida
    With entune (my radio) I can check a box that keeps the radio brightness at a constant level and doesn’t change when I turn on or off the headlights. If I uncheck it, the brightness changes. Might be vice versa but premise is the same.
    Changing colors, I do that by going into the settings menu on the gauge cluster.
  9. Nov 29, 2018 at 8:24 AM
    Gator352
    Leesburg, Florida
    The black thing, if I twist left, it dims the brightness of the dash lights. If I twist right, the brightness increases. And yes, your lights have to be on for you to increase, decrease brightness.
    Yeah, having lights, marker lights, and DRL’s on, it darkens my entune brightness. Like night mode if you will.
  10. Nov 29, 2018 at 8:53 AM
    Jayscull
    Jayscull Well-Known Member
    Jay
    Florida
    19 Sport
    I just got my first Tacoma on Black Friday, and this is the only thing I find annoying about the truck. Why does the auto headlight sensor only come with the premium packages?? It's been well over 10 years since I had to manually turn on headlights. In the case of my Tacoma, it effects the night/day mode of dispay. I guess the most logical fix is to replace the head unit with an aftermarket brand???
  11. Nov 29, 2018 at 8:56 AM
    Gator352
    Leesburg, Florida
    Heck, my old 2015 Dodge Dart has auto headlights. My 2018 Tacoma doesn’t.
